Results 1 to 15 of 101
14th Aug 2013, 07:09 PM #1Most Valued Member
- Jun 2012
- SA
- 1,649
Why you need an air micro die grinder
Been at it again.
Here's the latest video.
Why you need a cheap air pencil die grinder - micro die grinder - YouTube
Rob
14th Aug 2013, 09:32 PM #2
Go at it Rob. I'll watch your vids to see what is possible with the die grinder then I don't have to try stuff just to find out. I'll let you do it.
14th Aug 2013, 09:49 PM #3Most Valued Member
- Jun 2012
- SA
- 1,649
In the situation shown in the video, it would be difficult to open out the hole any other way. Maybe a very tiny carbide boring bar ?
I recon these little die grinders are the bees knees and being absolutely dirt cheap there's no reason not to have one.
I couldn't do that sort of job with my full sized tool post grinder.
Rob
14th Aug 2013, 10:33 PM #4
14th Aug 2013, 10:52 PM #5Most Valued Member
- Jun 2012
- SA
- 1,649
Some extra pictures
You can't compare these to a proper TPG, but as shown in the video they can do small stuff that would be difficult any other way.
LIke a Dremel, to be useful you have to buy the accessories - carbide and diamond burrs especially.
Here's a few photo's I took that I was going to add to the video but left off.
You may find them interesting.
Rob
14th Aug 2013, 11:30 PM #6
Thanks Rob. Did both knurling wheels require adjustment?
14th Aug 2013, 11:58 PM #7Most Valued Member
- Jun 2012
- SA
- 1,649
Hi Dean,
Yes, both were just a tad undersize. Enough to be a major problem.
I did actually try a drill before I used the air grinder, and no way that metal could be drilled.
Being Chinese I thought they may be cheesy, but not so. I got the scissor knurl from the UK and it seems to work OK. Probably made in China as well
Anyway, seeing as we were discussing these little grinders recently I thought it was a good opportunity to show what they can do.
People probably look at them and think what would I use that for ? but once you get one it's surprising how handy they are.
Rob
15th Aug 2013, 11:10 AM #8.
- 6,459
Rob, Dean,
I have some metal to remove on a little cast iron project that I have been dragging out because my Dremel can't access the areas I need to work on leaving me with dainty jeweller's riffler files as my only means.
There is an abundance of similar looking pencil grinders on Ebay with hugely varying prices. Richard"RC" splurged and dropped 50 bucks or so on a CTC grinder. Some of the others, the pink anodised versions, sell for around 30 dollars.
What exactly do you have?
Bob.
15th Aug 2013, 01:19 PM #9Most Valued Member
- Jun 2012
- SA
- 1,649
You hit the nail right on the head - the pink anodised ones are all the same as far as I can tell. Some people just try and charge more.
I got mine from a CTC Ebay outlet (they have a few) for about $30 delivered.
Prices have gone up a bit since then as our $ is not as good.
MICRO AIR GRINDER #C99
They also do a 4 bearing model which is more for continuous use.
MICRO AIR GRINDER - STRAIGHT HEAD #G69
Plenty on Ebay exactly the same even cheaper eg:
NEW AIR Micro DIE Grinder Tool 17 PCS Mounted Stone Grinding Polishing Engraving | eBay
I'd have no hestitation buying any of them.
I did a web page on them a while back which gives a lot of information, and how you can get the best performance out of them (an easy collet modification).
Air micro die grinder
Rob
15th Aug 2013, 03:56 PM #10Ring Master
- May 2006
- Lake Macquarie NSW Australia
- 73
Try Bunnings - Just bought - Trade Air - Micro Grinder Kit (17 Pce) - $24.00
Clearance prices - get in quick!
regards Ned
15th Aug 2013, 07:49 PM #11Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
15th Aug 2013, 07:58 PM #12Most Valued Member
- Jun 2012
- SA
- 1,649
Not listed in the catalogue on line for Bunnings stores in SA.
Rob
15th Aug 2013, 08:53 PM #13
I bought this one NEW AIR Micro DIE Grinder Tool 17 PCS Mounted Stone Grinding Polishing Engraving | eBay.
Same as Rob I think. Was $3.00 cheaper than in this link.
16th Aug 2013, 09:46 AM #14Most Valued Member
- 4,258
16th Aug 2013, 10:28 AM #15Most Valued Member
- Jun 2012
- SA
- 1,649
Be interested to hear what you think of it.
Get the burrs etc and you are set to go.
Rob
