Results 1 to 7 of 7
Thread: Plastic dipping DIY
1st Jun 2013, 09:43 PM #1Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Plastic dipping DIY
Is it possible to do plastic dipping at home? I would like to re coat the handles of a pair of pliers etc.
Ken
1st Jun 2013, 09:53 PM #2
Hi Ken,
Isn't plasti dip designed for stuff like that, or is it too hard? I'm sure someone on the forum has commented on it before.
Home
1st Jun 2013, 09:56 PM #3
Hi Ken,
Yes there is. It's name may be something like Plasti-Dip.Its a granulated powder product. You heat the item to be coated with a gas flame and dip it in the powder.
Edit after a google :
That was when I was at school years ago,its now changed a bit.
Here tis now
Performix / Plasti Dip
1st Jun 2013, 10:37 PM #4Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
maybe
there's rubber paint. if you can believe the info on the lable. it looks like a good product.
1st Jun 2013, 10:38 PM #5Most Valued Member
- 70
- 1,513
Heatshrink tube works well, especially the double walled stuff.
Nev.
2nd Jun 2013, 08:41 AM #6Senior Member
- Jan 2004
- Bellingen
- 278
You can also get heat double wall heatsrink with a glue on the inside. It stops it from twisting off with heavy use and helps block out the moisture as well.
5th Jun 2013, 04:08 PM #7Most Valued Member
- 4,258
mmm...if the existing plastic is damaged and if you do any electrical work I"d strip all the old plastic off ...and then go buy a new insulated pair for electrical
