Results 1 to 15 of 72
Thread: Shed heating ornament
28th May 2013, 10:59 PM #1Senior Member
- Apr 2010
- Rural Victoria
- 358
After a loooooonnnnngggg time I have finally found motivation to finish my shed pot belly.... or did I finally realise that moving to a higher altitude it gets a bit colder in the shed at night?
Here is a mock up of the parts which have been compulsorily acquired thus far:
The basis is a couple of brake drums off a prime mover. The other basic parts are a ring which sits in between the two drums and a plate to cover the holes top and bottom, and some way to get rid of the smoke. Mine is somewhat more elaborate because I have access to CNC lasers and as with everything I make, it has to have extra '#### factor'
I am attaching the top and bottom plates with 'rivets' made from some laser cut washers and short lengths of 20.0mm merchant bar. These are pushed through from inside and are plug welded to the plate on the outside. Plate has the same PCD as the brake drum.
The 20.0mm merchant bar has to machined down to about 19.0mm to fit through the holes in the brake drums.
I will post further updates as I progress.
I realise that this is nothing new to some of you guys... but these things are so easy to build I thought I might throw it up here for those who haven't seen it done before.
The simplest design I have seen has only one bolt on the 'lid' which acts like a pivot. The lid is moved sideways to open the top of the stove to throw in the wood.
As stated in the title of the thread, this is a 'shed heating ornament'. No doubt you will suffer the wrath of OHS pedants and tree huggers if you actually start a fire inside the thing. What you do after it is constructed in the privacy of your own home is entirely your business.....
29th May 2013, 02:46 AM #2
I will keep watching to see how you get on. I have a couple of tractor rims that are slightly bigger than the brake drums which are to be used for the same purpose one day. Mine will be a bit too big for the shed I think. Never get in to the shed with it going anyway.
29th May 2013, 06:43 AM #3Pink 10EE owner
- 6,218
Very nice, I need to make something like that, why just the other day it got under 20C in the shed and was freezing..
29th May 2013, 09:29 AM #4Most Valued Member
- 4,258
29th May 2013, 09:31 AM #5Most Valued Member
- Charlestown NSW
- 1,673
G.S
I noticed you use the term "merchant bar" which is one I haven't come across before. Can you explain please? I'm assuming its what we, in the backward northern states, call "black bar" but I might be wrong. (apparently I am, quite frequently.)
bollie7
29th May 2013, 12:11 PM #6Senior Member
- May 2012
- Vermont 3133 Victoria
- 248
Made a similar unit with the intention of it going into the workshop, but it ended up outside as I had to remove 100 cubic mtrs of dirt/rock from under the house to fit the work shop in. Never did get around to getting permission from the wife to relocate it.
Cheers Bruce
29th May 2013, 12:14 PM #7Most Valued Member
Looking good so far.
Can't imagine the hoops I'd have to jump through to get that in my shed.
I have a little gas "jet" heater for my shed, works great but has little "Charm", the noise it makes doesnt do a lot for the serenity, costs about $3.50 an hour to run and you cant heat anything up on/in it.
Still I guess the up side is you wont leave your finger prints on it either
29th May 2013, 12:21 PM #81915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
29th May 2013, 01:26 PM #9Member
- mid north coast NSW
- 92
bollie7, I've used the term merchant bar for last 20 years or so, to describe the lowest grade common (black) steel bar or rod, what we use to call "mild steel." The modern "merchant' bar isn't mild any more as I think it is higher in carbon and other alloys from being made from scrap in Mini mills? but what I do know is it that will harden if quenched from a red heat after forging, something that the old mild steel wouldn't do! t Graeme
29th May 2013, 01:56 PM #10Most Valued Member
- Charlestown NSW
- 1,673
29th May 2013, 08:12 PM #11Member
- Sep 2008
- lillimur
- 86
Eskimo and anyone else,
I have plenty of truck brake drums available for pickup in Melbourne or Adelaide.
PM me with your needs.Free.
John
29th May 2013, 08:26 PM #12Member
- Dec 2010
- Mornington Peninsula
- 97
29th May 2013, 08:33 PM #13Member
- Sep 2008
- lillimur
- 86
Derrimut or Regency Park
29th May 2013, 09:09 PM #14Member
- Dec 2010
- 97
29th May 2013, 09:16 PM #15
Heating jig
By Tiger in forum METALWORK GENERALReplies: 10Last Post: 2nd Mar 2006, 08:16 PM
