Results 1 to 15 of 17
Thread: Tool holder I.D. ?????
14th May 2013, 12:15 AM #1
Hi
I was reading Harold Halls write up on making the plug gauges for his chuck and backing plate projects
He uses a particular brand of tool holder and insert for the threading
Does anybody know the brand of the tool holder and the insert he is using ?
Mike
14th May 2013, 08:54 AM #2
Looks like the Glanze external threading tool and insert.
New Glanze Indexable Threading Tools and Sets
I have a set ofexternal and internal Glanze threading tools.
14th May 2013, 01:29 PM #3
thanks
THANKS BUT IT LOOKS MORE LIKE THIS
SET OF Imperial External Lathe Threading Tools 16mm Shank | eBay
14th May 2013, 01:33 PM #4
14th May 2013, 01:37 PM #5Dave J Guest
I am not up on inserts, but I am sure Bob posted one last week similar to it. It is my understanding they are called full form inserts as they only do one (or a limited number) of threads per inch.
Is there a reason why you don't just use HSS, or are you turning hardened steel?
Dave
14th May 2013, 01:54 PM #6Most Valued Member
- Oct 2007
- 3,112
14th May 2013, 01:59 PM #7
14th May 2013, 04:15 PM #8Banned
- Jul 2011
- Melbourne Australia
- 1,376
That style is generally called a laydown threading insert. Lots of companies do them. Using that term will help you find them.
They come in full form, and general vee styles. The full form ones make threading a breeze. You just leave your stock slightly oversize 0.05 - 0.1, and keep cutting until your diameter starts to reduce. You just micrometer that, then finish to the major diameter. Provided you haven't worn or chipped the insert your depth and form would almost pass inspection. You can get them in odd ball stuff like Acme and Trapezoidal as well.
I traded off a few hour service call at one of my repetition companies, for a box full of mixed pitch internals and externals. They really make thread cutting half as hard as it used to be.
Regards Phil.
14th May 2013, 07:08 PM #9Philomath in training
- 6,559
Phil, at the risk of sparking controversy, do you set the compound across at 29 degrees with these inserts or plunge in square (compound parallel with the bed)?
14th May 2013, 07:42 PM #10
form
14th May 2013, 08:32 PM #11Dave J Guest
It's all in the grinding and stoning. For threads that need it I just use my my eye loupe (about $3 off ebay) and round it off.
A lot of the time I will off set or angle my tool bit grinding to get in close to a shoulder etc.
Dave
15th May 2013, 12:57 PM #12
ozmestore
the same set is available here ..looks to be Asian to me ...It must be reasonable quality otherwise Chronos wouldnt sell it ..maybe MIKE
AT LEAST THESE SETS ACCEPT A STANDARD INSERT , UNLIKE SOME
7PCE Internal External Thread Insert 10mm Tool Holder Free Postage | eBay
15th May 2013, 01:33 PM #13
Certainly looks similar, can't find the separate inserts in his listings though?
15th May 2013, 09:54 PM #14
I have a Glanz boring bar, certainly no iscar but it was cheap. The inserts (diamond shape, maybe 70 or 80 deg point) that came with it were crap, and the torx bit broke off the first time i used it.....I think they are made in India.
Personally i have never used a carbide threading tool, the only problem i have had with HSS was threading silver steel and the trailing edge pushing metal up onto the ridge causing the ID to grow. Only happen with the O-1 though, not on anything else.
If i was to buy some i would look at CTC.
15th May 2013, 11:21 PM #15Banned
- Jul 2011
- 1,376
At the risk of getting burn't at the stake. I havn't turned a compound around since I was an apprentice. H.S.S or the newer carbide form tools. I just plunge cut.
At the end of the day, speaking of these thread form tools. The forms ensured when the leading edge, trailing edge and crest are cutting. In CNC thats mostly the G76 function. That does a Z axis offset getting to depth, but the final spring cuts are at depth.
Wasn't it John Stevenson that ripped his entire top slide off and replaced it with solid mount. He does alot of threads. All of them must be staright in.
Regards Phil.
tool holder id
By azzrock in forum METALWORK GENERALReplies: 10Last Post: 8th Dec 2011, 03:25 PM -
hss tool holder
By tanii51 in forum METALWORK GENERALReplies: 3Last Post: 11th Nov 2009, 08:31 AM -
tool holder
By glenn k in forum THE HERCUS AREAReplies: 5Last Post: 17th Apr 2009, 03:50 PM -
Tool Holder for Hercus etc.
By Buncha in forum THE HERCUS AREAReplies: 1Last Post: 16th Sep 2008, 04:23 PM
