Results 1 to 9 of 9
Thread: Home made Lathe
    Aug 2011
    4,779
    Default Home made Lathe
    While looking at the "Cheap Steel" thread and YouTube Video by nearnexus, I found this video on a home made lathe and ELS. Best home made lathe I have ever seen!
    I would like to know whether it has rigidity issues since it's made of mild cold rolled steel instead of CI. It seems quite capable of heavy cuts.
    Homemade Metal Lathe. (w/ simplest electronic lead screw) - YouTube
    Fixed the link!
    Dave J Guest
    I doesn't look like the bed rails where machined , so over a short distance they would be fine but over the whole length I don't think it would be very true, but I could be wrong as he might have had them machined or ground.
    The electronic lead screws have been around for a long while now.
    Dave
    Aug 2007
    68
    1,410
    where there is a will, there is a way.... incredible what a really determined person can do with very little expense....
    I would not expect rigidity to be a problem. The difference is that cast iron dampens vibrations, whereas a fabricated steel lathe bed may "ring like a bell", In other words, it may amplify vibrations that are close to its resonance frequency, instead of dampening them. Of course there are tricks, like filling a hollow fabricated steel structure with concrete. Chris
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    It certainly looks the part. It even sings to you....
    It sounds like its in a heavy industrial setting, thats a fair bit of banging going on in the background
    Jun 2012
    SA
    1,649
    Wow, that's something else.
    Amazing job. Great video.
    Rob
    Dave J Guest
    I don't know whats going on, but I am sure Fred posted about it being the wrong link, then I posted under him and wrote amazing with the correct link, but now both posts are gone, mmm, maybe I am imagining things.
    Dave
    Nov 2006
    Bendigo Victoria
    80
    7,471
    Dave
    No, not imagining Dave. I reported that the link was wrong, you put the right one up, then Simon corrected his original (wrong) link, so I deleted all that toing and froing as it was now superfluous and detracted from the thread.
    However............
    Dave J Guest
    Thanks Fred, it just my now first post sounds as if I am questioning the lathe, but my first post was stating it was amazing.
    Dave
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    WOW, what an achievment. I didn't get to see all the Video due to Youtube freezing up. I like the Idea of the Car Gearbox.
    All The Best steran50 Stewart
  1. Impressive home made lathe
    By racer123 in forum METALWORK GENERAL
    Last Post: 15th Oct 2011, 03:26 PM
