Results 1 to 9 of 9
    May 2012
    Vermont 3133 Victoria
    248
    Default Interstate Grays auction pickup
    Hi Gang,
    Has anyone ever used a courier service to do a Grays auction pickup.
    Bruce
    Mar 2012
    Western NSW
    543
    Quote Originally Posted by argeng View Post
    Hi Gang,
    Bruce
    Hi Bruce, I have used e-go couries (online booking) a number of times to pick up items from Grays auctions. I have never had a problem and I consider them cheap. I try to limit it to smaller items, say 20-30kg or less as this is easier for them to pick up with one man but they will do larger items but obviously this would require a lot more organising. Hope this helps.
    Mark
    Jun 2006
    Vic
    5,631
    Haven't used a courier myself but I've quite often been engaged to pick up items which required a cranetruck. Just need to make sure you follow the guidelines outlined by Grays to allow third parties to collect the goods on your behalf.
    DJ
    ​ADMIN
    Jul 2008
    near Warragul, Victoria
    3,726
    Default e-go
    I have used e-go a few times, for moving lathes etc. Never had a problem with them. If you can , use the e-go depot to depot service, it's so much cheaper than door to door delivery . They also offer door to depot , which is handy. They will store the item for 3 working days at their depot ... after which, you pay storage . What is important, is to ask or beg the seller to pack/secure the item correctly, some of the sellers don't give a toss and that's when breakages occur .
    Mike
    May 2012
    248
    Quote Originally Posted by markgray View Post
    Mark
    G'Day Mark,
    Thanks for the reply, That is what I would be needing, Grays auction is in NSW, Lidcombe, 2141 I am in Vic item would be max 20 Kg if that.
    Bruce
    May 2012
    248
    Quote Originally Posted by DJ's Timber View Post
    DJ's
    So do you have access to a crane truck, what about a pick up Bayswater to Vermont 1100 kgs, straight drive in Bayswater, slight incline Vermont, have had full size cement ag, no problems and large tilt slide to deliver 1600 kg lathe.
    Cheers Bruce
    May 2012
    248
    Mike
    Thanks Mike,
    With Grays it would be grab whats there and thats about it.
    Bruce
    Jun 2006
    Vic
    5,631
    DJ's
    Cheers Bruce
    Yes I have a crane truck, can pick up 3000 kgs with the crane next to the truck or 1200 kgs at full extension which is about 6mts. Can pick up heavier loads upto about 4500 kgs but requires judicious handling and extra work to do it.
    Bayswater to Vermont is no prob, will send you a PM.
    DJ
    ​ADMIN
    May 2011
    Castlemaine
    244
    Default Pack Send
    Bruce,
    I have used Pack Send in Auburn to pick up stuff from Grays. Send them an email with a photo of the item and its weight and they will give you a quote.
    I used them to pick up a Mitutoyo vernier protractor. I was worried that the lose parts in the box might scratch the magnifying glass so I asked him to cover it with sticky tape which was not a problem. Everything was individually wrapped in bubble wrap.
    I can't recall how much the cost was but the service was very good.
    Piers
