Results 1 to 15 of 18
Thread: Backing plate material
6th Jan 2013, 04:41 PM #1future machinist
- Mar 2008
- nowra
- 1,598
I need to make a new backing plate for a 4" 3 jaw chuck I acquired what would be the most suitable material to make it out of
Andre
6th Jan 2013, 04:52 PM #2
Hi Andre,
Some cast iron would be best, i think there is a Bohler at Uninnderra (spelling)? I have used a couple of different sized exercise weights brazed together to make one before, there is no supplier in Canberra who has cast iron, although i have found out that a place may be able to order it in cut to size. I hope they can!
Good excuse to make a plug gauge too.1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
6th Jan 2013, 06:31 PM #3future machinist
- Mar 2008
- nowra
- 1,598
Thanks Ueee
Another question Could anyone give me a rough guesstimate as to what a suitable piece of cast iron might cost.BETTER TO HAVE TOOLS YOU DON'T NEED THAN TO NEED TOOLS YOU DON'T HAVE
Andre
6th Jan 2013, 06:51 PM #4
scrap
Andre you might try going around some of the clearance sales in your area , you might find an old trolley wheel or similar. Look in your local paper for sales ....when you find a chunk of iron .... you will be
6th Jan 2013, 07:20 PM #5Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Andre
Another great source is tractor weights. The ones that used to hang off the front. I could get you an old battery stamp from work. They are some seriously good quality SG cast iron but incredibly heavy to mail out.
Phil
6th Jan 2013, 07:21 PM #61915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
6th Jan 2013, 08:14 PM #7
6th Jan 2013, 08:52 PM #8Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Backing Plates
Andre
Good to hear from you again.
You have been off the air for a while.
Firstly, how is the Shaper scraping proceeding?
I have photos here of the scraped head,I did some time back, & must put them up on the forum soon.
Been having a bit of trouble transfering photos, to the forum sight.
Getting back to the backing plates, do not do what I did.
It took me ages to cut a blank out of an old Heine die set & machine it up internal screw cut etc. I mean a lot of work !
Cant remember the lathe you have but there are a number of places that supply the cast piece ready for machining.
Australian Metalworking Hobbyist is one. Try contacting Mal if the size is right I would go with that avenue.
regards
Bruce
6th Jan 2013, 10:31 PM #9Most Valued Member
- 4,887
7th Jan 2013, 07:36 AM #10Senior Member
- Jan 2004
- Bellingen
- 278
What about old disk brake hubs off cars? I'm pretty sure they are cast iron but im sure someone here would know. should be easy enough to pickup.
7th Jan 2013, 08:45 AM #11Most Valued Member
- Jun 2012
- SA
- 1,649
Doesn't have to be cast iron.
I've machined up a couple of these from 50 and 70 mm thick steel boiler plate.
Go to a heavy engineerig works and have a chat to them about off cuts.
You can use the circular cut outs that they make when cutting round holes in steel plate for pipes to go through etc.
They also have round stock off cuts from the ends.
You pay normal new steel price but it works out pretty cheap - if you size it right - $20 or less.
As this stuff is all flame and plasma cut you will have to grind off the hard slag before turning it.
Rob
7th Jan 2013, 09:47 AM #12Pink 10EE owner
- 6,216
7th Jan 2013, 09:53 AM #13
I just ordered a chunk for the verniers clamp, it works out at $5 a kilo plus gst and some freight.
8th Jan 2013, 05:10 PM #14Golden Member
- Mar 2009
- 54
- 825
I found a good source of cast iron disks is the belt rollers from old treadmills, the non motorised type.
You can usually find heaps of them at your local tip shop and pick them up for around $5.00.
I have found the cast iron to be better quality than old weights, especially the cheapo ones which tend to have lots of sand inculsions.
Each treadmil will give you four nice disks that would be ideal for making backing plates for small chucks up to around 5".
Greg.
11th Jan 2013, 04:58 AM #15future machinist
- Mar 2008
- nowra
- 1,598
chuck backing plate
By welder in forum THE HERCUS AREAReplies: 5Last Post: 2nd Feb 2010, 05:26 PM
