Results 1 to 10 of 10
17th Dec 2012, 02:28 PM #1Most Valued Member
Need help identifying the electric motor!
Hi all,
I just bought this motor for what appeared to be a song at $20. Now I'm not so sure! I was hoping it was at the very least 415 Y but now I'm not so sure. I have taken it apart but I can't find the Y connection inside. looking at the plate, can someone see something that I can't that would indicate it's 415 Delta?
415 Delta is no good to me! I'll probably get my money back at the scrap metal place but it would be a shame.
Thanks,
17th Dec 2012, 02:36 PM #2Most Valued Member
It's a little hard from here Simon, I dont have anything that powerful
17th Dec 2012, 02:54 PM #3Most Valued Member
Yea yea. I know you have some good optical stuff, stuff that would probably rival the Hubble space telescope but I should really include a photo anyway!
Sorry, here it is:
Also did a search on the MLA 2107 motors and all I could find was this in relation to the starting method:
Three-phase standard motor | Motors | Fuji Electric Global
3.7kW or less: Direct-on-line (full voltage) starting
5.5kW or more: Star-delta starting
From the Fuji website:
Thanks!
17th Dec 2012, 03:39 PM #4Most Valued Member
Hi Simon,
I'd say the star point is in there somewhere. While you could make a 415V delta wound motor, there wouldnt be much point(in a motor of this size).
Arent you replacing a 2hp motor? Have you considered running it as is?
17th Dec 2012, 03:50 PM #5Most Valued Member
Hi Stuart,
Are you suggesting that most 3 phase motors of this size are 415V Star wound?
I could give it a try and use it as is, I just assumed it would be way way down on power & torque. I have a power meter, I could hook it up to the input of the VFD and see what it draws, that would give me a pretty good idea.
17th Dec 2012, 04:17 PM #6Most Valued Member
Hi Simon,
Yes thats what I am suggesting. I "think" if you wound them for 415delta you could get the same end result but would use more wire......... but I could be wrong.
Thoery says you'll have about 60%hp. I run a couple of motors in delta.
Now what happens above and below rated Hz I dont know. i.e. On a 240V vsd, will a 415V star wired 3hp motor lose less power at 25Hz than a 240V delta wired 2hp motor? And the same at say 75Hz?
17th Dec 2012, 04:17 PM #7
Hi,
If you are nosing around inside the motor, you should be able to see if 2 coil ends are connected to each terminal lead, if so it is delta, if only one the other end of each coil is connected to a star point some where.
RegardsHugh
Enough is enough, more than enough is too much.
17th Dec 2012, 05:15 PM #8Most Valued Member
Thanks Stuart & Duke,
Ah yes I should have thought about that. All Delta wired motors have external wires connected to 2 wires either inside the junction box or inside the motor.
I'll have another look. My last motor was star and the Y point was very easy to find, maybe I was just lucky with that one!
17th Dec 2012, 06:19 PM #9Most Valued Member
Hi guys,
Yep definitely Star wired. I found it, eventually!
Thanks for your help!
17th Dec 2012, 09:54 PM #10
RegardsHugh
