Results 1 to 7 of 7
Thread: Shaper vice and milling vice
3rd Sep 2012, 07:16 PM #1
I seem to be confused . Are they the same thing, or not ?
Mike
3rd Sep 2012, 07:37 PM #2
They both have the same function: holding work pieces.
On a shaper, there will never be a tool entering the space between the fixed and moving jaw to any depth, so shaper vices can use a screw that crosses in this space. That would be too risky on a drill or mill, particularly a vertical mill.
This screw allows large vices to be built relatively 'light' with the tensile strength of the screw being the limit of force - so the two jaws a PULLED together. THe base can be relatively 'slight', as it doesn't transmit any forces.
A milling or drilling vice uses the screw to PUSH the moving jaw and the base needs to be solid enough not to break under the tension force being transfrerrd through it, and the ways need to be big enough to resist the moving jaw tilting while being pushed.
Most often, shaper vices are rather large and as a result heavy all the same, mind you.
Joe
3rd Sep 2012, 08:07 PM #3
pic
OK Joe
this pic depicts a shaper vice .. it doesnt seem to different at first glance
3rd Sep 2012, 09:35 PM #4Philomath in training
- 6,542
I'm sure that a lot of shaper vices have ended up on mills. The one difference I would point out is that a shaper vice (such as the one you have pictured) usually have 4 bolts holding them down, where as a milling vice normally has two.
3rd Sep 2012, 09:48 PM #5Most Valued Member
But then the screw is in compression and the cast in tension!
Though I agree shaper screws are in tension and mill screws are in compression. And that steel in tension and cast in compression(as in the shaper vice) is the way to go. But I dont have a better reason.........
3rd Sep 2012, 11:59 PM #6Most Valued Member
- Healesville
- 2,129
and then you also have the shaper vice's with two screws, such as the vice of happyness.
http://www.woodworkforums.com/f65/sh...ml#post1495268
5th Sep 2012, 12:06 AM #7
Shaper vice project
By welder in forum METALWORK GENERALReplies: 49Last Post: 19th Jun 2012, 08:42 PM -
SOLD: Douglas Shaper Vice
By 4-6-4 in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 30th Apr 2012, 12:11 AM -
Which Shaper does this vice belong too?
By lamestllama in forum METALWORK GENERALReplies: 16Last Post: 12th Apr 2012, 01:52 AM -
Milling Vice
By eskimo in forum METALWORK GENERALReplies: 27Last Post: 17th Aug 2011, 06:00 PM -
N.S.W. Wanted to buy Shaper Vice
By Dave J in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 10th Jun 2011, 10:33 PM
