Results 1 to 15 of 20
Thread: Servo electronic threading
27th Aug 2012, 06:16 PM #1
Thought I would share this link about a servo driven electronic threading conversion. Would seem to be a nice addition.
These guys also do some very nice restoration jobs on Hardinge lathes. I would like to get their painter to do my ute .
Babin Machine ToolMicheal.
28th Aug 2012, 12:22 PM #2Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Do some Googling before doing business with that guy. Caveat emptor.
28th Aug 2012, 04:10 PM #3
Hi Bryan, I did some googling and came up with a few links to a Different person. Not related at all to the link I posted as far as I could tell.
Micheal.
28th Aug 2012, 06:51 PM #4Banned
- Jul 2011
- Melbourne Australia
- 1,376
Yep, That one is Paul Babin, no relation to the Al, Allen, Mike, Hillary, LAtool Babin.
Paul Babin seems to have a good reputation, with the guys that have done business with him, at the P.M Forum.
In summary.
Babin from Connecticut = bad.
Babin from Massachusetts = good.
Phil.
28th Aug 2012, 10:05 PM #5
I like the idea of an electronic leadscrew control. A guy in Canada sells an inexpensive ELS kit for stepper or servo power.
Taken to its logical conclusion it would be great to have an infinite speed ballscrew with a jog/move control to allow for "manual" feeding...you could then eliminate half nuts and the rack.
Eisen in Taiwan make an HLV-H clone with such a system
CTL-618DT Super High Precision Toolroom Lathe with Digital Threading - Eisen Machinery IncIt's all part of the service here at The House of Pain™
28th Aug 2012, 11:21 PM #6Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
My mistake. Thanks guys for clearing that up.
28th Aug 2012, 11:33 PM #7
Yeah, if I was Paul in Mass. I think I'd rename my business to "The Good Babin"
GQIt's all part of the service here at The House of Pain™
29th Aug 2012, 12:00 AM #8
Hmmm that would be a full CNC lathe I guess...
I also like the electronic lead screw idea, I was at Schachermayer's in Linz yesterday eyeing off a CNC lathe, a Weiler similar to this one WEILER Praktikant VC Plus
Electronic Lead screw is a nice idea and very likely do-able as as retro fit for quite a few machines...
29th Aug 2012, 12:10 AM #9
I was considering doing an ELS on my lathe but then stumbled upon the genuine gears that I was missing on PomBay for next to nowt. To complete my set I only need a 40 tooth, but it can wait til the Deckel is going as I have the 1.5 modul cutter set on the shelf here. The Canadian ELS also has provision for a powered cross slide which enables taper cuts and power tool retract for fast threading.
Electronic Lead Screw Main Page
GregIt's all part of the service here at The House of Pain™
29th Aug 2012, 07:38 PM #10
Hi GQ,
Thanks for that link, I hadn't seen it before, looks like a good project.
29th Aug 2012, 11:27 PM #11Cba
- Aug 2007
- 68
- 1,410
Greg, the Canadian ELS is perfect for threading things like fasteners. And at the same time provides an infinite number of automatic feeds via the half nuts. But it is useless to make acurate threads like leadscrews.
This is so for two reasons. Once because of recursive rounding errors by the software. It is only very little every revolution, but if you make a leadscrew it may easily be half a turn out of pitch after 100 turns. Imagine the leadscrew of your lathe being 1/2 turn out of pitch from end to end..... The other reason is that the pitch linearity from turn to turn is dependant on the cutting forces and the spindle motor speed regulation. This is because the main spindle has only one syncronisation pulse per revolution. The electronics can only detect a syncronisation error between main spindle and leadscrew once every full main spindle revolution. Imagine the spindle slowing down during a cut, but the leadscrew continuing at a steady speed. Then the error is detected and the leadscrew slowed down.... the result is a slightly drunken thread. Both problems will not matter in most practical cases, but you will never be able to make an accurate spare leadscrew with this ELS.
It is surprising how difficult it is to design an electronic equivalent to a humble gear drive that is even remotely as accurate! Chris
29th Aug 2012, 11:48 PM #12
Ray & Greg: that's the ELS (Electronic Lead Screw) kit I built for my feedscrew-less lathe. Just not quite yet fitted....
Chris: the recursive error thing has been solved some time ago after a very very very long discussion on the ELS Yahoo group with lots of experts contributing to the algorithm correction. The current processor code allows you to do accurate long threads.
There was a comparison article in one of the model engineering magazines (I think it was Model Engineer's Workshop) that reported that the British equivalent device (not kit) was able to long threads and the ELS kit was not - but they based the comparison on an older version of of the software. That was a pity.
The ELS kit, by the way, is sold by the co-ordinator of the open source ELS project that ran for quite a long time on the CNC Zone forum a few years back. His name is John Dammeyer and he is very easy to get along with and most helpful in every aspect of building or implementing the ELS.
One of the biggest advantages of the kit for me is that it can drive both Z and Y axes on a lathe and allow you to make taper and parallel threads in any pitch or TPI irrespoective of the leadscrew pitch, do accurate tapers and automate repetitive tasks without all the steps in software that CNC would require. It also has a CNC interface that allows Mach 3, Turbo CNC or whatever to interface and drive the axes motor controllers without having to have two sets of these if one wants to do both.
I like the idea of a stand-alone solution a lot for a lathe.
Joe
31st Aug 2012, 12:02 AM #13Cba
- Aug 2007
- 68
- 1,410
Joe, I understand the recursive error is due to floating point math erors with the 8bit PIC. It can only be solved with a more powerful processor. The other problem was due to the 1 pulse per revolution spindle encoder. Again, the 8bit PIC is simply too slow to handle multiple pulses from a real encoder. See also John Dammeyer's messages 5042 and 5053 in the ELS group. It would be really great news if John found a solution - but I do not think he had a breakthrough yet. I have been very interested in John's ELS from the beginnings, even took out a "circuit cellar" subscription only to get my hands on his detailed article on the ELS project. I never built one, exactly because of the above issues. But would be glad to reconsider if one day it can cut threads with an accuracy that approaches what a simple gear driven leadscrew is capable of.
The English ELS you mention was the "Frog", sold as ready made ELS for the little Sherline lathe. It suffered from the same single pulse encoder problems though. And before this, a certain Fritz Link had published the plans and diagrams to make an ELS for an Emco Compact 8 lathe, using a fast PLL circuit with technology from the late 70's with homemade multipulse encoders, this was accurate but rather complex....
Anyway, you now built one of John's ELS and I hope you will be posting pics and let us know your experience with it. Chris
31st Aug 2012, 08:08 AM #14Senior Member
- Jun 2012
- Germany, Outback of Munich
- 211
Though I don't know how ELS does it.
Nick
31st Aug 2012, 10:39 AM #15Cba
- Aug 2007
- 68
- 1,410
Nick, this is not a fundamental problem, it all has been solved long ago for industrial grade CNC by throwing money at it.
The ELS in question is a very low cost open source project dating back to 2005. see here:
It can be built for under AU$500 (the kit is $250, then you need some extra bits like stepper motor and enclosure etc). It is aimed at smaller lathes like the South Bend 9", which either never had a quick change gearbox, or where change gears are incomplete or went missing. To keep this project affordable for the backyard workshops, John had to compromise. The 8 bit processor just cannot do the job fast enogh to accomodate the requirements for making long threads wit accuracy. Other than that, for the modest outlay it is a very powerful ELS than can create threads of any pitch (metric or imperial or module) on any lathe equipped with a leadscrew. Unlike a real CNC conversion, the machine remains in every respect a manual lathe. The ELS simply takes the place of a (very complete) Norton gearbox. Chris
Where to buy electronic micrometers
By steran50 in forum METALWORK GENERALReplies: 4Last Post: 11th Aug 2012, 03:22 PM
