Results 1 to 15 of 98
Thread: Diamond Tool Holder
30th Jul 2012, 06:23 PM #1
Diamond Tool Holder
I am looking at ordering a Diamond Tool Holder from Eccentric Engineering, together with a 1/4" Crobalt tool bit.
I am a little uncertain as to which size to get. I have a 9x20 Steelmaster lathe, which I use with an AXA Quick Change Tool Post. Eccentric tells me to measure the distance from the bottom of the tool groove, where the tool holder sits, to the centre line line of the lathe.
http://www.eccentricengineering.com....id=6&Itemid=19
On my lathe/QCTP combination this is about 10.5mm, so I assume that I need to order a 9.5mm Diamond Tool Post?
Is this assumption correct?
What do others with this combination use?
30th Jul 2012, 06:46 PM #2.
- 6,459
Hey Fred,
I purchased the 9.5mm holder for my 9" Hercus. Initially I thought I needed the 12mm holder but I rang Gary at Eccentric for clarification.
BT
30th Jul 2012, 07:00 PM #3
30th Jul 2012, 07:05 PM #4Most Valued Member
- 4,890
How many different sizes do they have.
Do you know what there centre height is.
Wouldnt you have to know how big there tool shank is,and then the centre height of there tool.
After looking at there web site its very self explainitory as to what they require you to measure,they even show a qctp in there diagram.Last edited by pipeclay; 30th Jul 2012 at 07:17 PM. Reason: more
30th Jul 2012, 07:46 PM #5
30th Jul 2012, 10:33 PM #6Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Fred,
I have an AL340D and they recommend 16mm tooling but I am assuming that is with a normal 4 way tool post. My first diamond toolholder was a 12mm (present from the missus) and it fits perfectly in the quick change tool post.
Hopefully this will help.
Phil
23rd Sep 2012, 09:06 PM #7.
- 6,459
I like it.
The only time previously that I had attempted to use my Diamond tool holder was when I had the Crobalt fitted and I tried to cut the outside of a slice of 160 mm diameter 4E cast iron bar. It had trouble achieving a good finish so I used a CCGT insert instead with OK results.
Today I had some facing to do on some 4140 that I had cut by hand with a hacksaw. Maybe as a lack of skill the blade wandered enough that the cut face was skewed and would have meant an interrupted for the carbide which often results in a broken insert. So I fished out the Diamond and fitted the HHS. The results were just superb. I applied neat non diluted soluble oil with a brush and ran the Hercus at 900rpm with a pretty delicate feed. The 4140 was 17mm in diameter.
The delicate feed was necessary because I couldn't afford to have the part fly out of the chuck as a result of a greedy, overambitious cut.
BT
24th Sep 2012, 08:15 AM #8Most Valued Member
- 4,258
the 1/2inch fits the AL960. These come in both LH and RH where as the bigger size does not....you can always pack a smaller one up and why doesnt my curser show up as to where I am supposed to be typing...is this still a problem with the new layout?......cant go back and correct a small mistake without deleting lots of words...is it just me?
24th Sep 2012, 09:22 AM #9
eskimo please don't hi-jack this thread with off topic posts, they have been moved to
http://www.woodworkforums.com/f36/so...ml#post1555567
which is the appropriate place to get help with updated forum problems.
24th Sep 2012, 11:32 AM #10Most Valued Member
- 4,890
24th Sep 2012, 12:54 PM #11.
- 6,459
Good question Peter,
I started using high positive Kennametal CCGT inserts when I purchased a SCGCR tool holder. They were what K2 Engineering, the seller, recommended. Subsequently, I've purchased more inserts on Ebay and stuck with the same specification. The third letter refers to tolerance. I don't know what the difference is between G and M. I should find out. Might lead to more, and more importantly, cheaper alternatives.
Bob.
24th Sep 2012, 02:48 PM #12
The 3rd character is the dimensional tolerance as per the following table.
Code Letter Cornerpoint
(inches)Thickness
(inches)Inscribed
Circle (in)Cornerpoint
(mm)Thickness
(mm)Inscribed
Circle (mm)A .0002" .001" .001" .005mm .025mm .025mm C .0005" .001" .001" .013mm .025mm .025mm E .001" .001" .001" .025mm .025mm .025mm F .0002" .001" .0005" .005mm .025mm .013mm G .001" .005" .001" .025mm .13mm .025mm H .0005" .001" .0005" .013mm .025mm .013mm J .002" .001" .002-.005" .005mm .025mm .05-.13mm K .0005" .001" .002-.005" .013mm .025mm .05-.13mm L .001" .001" .002-.005" .025mm .025mm .05-.13mm M .002-.005" .005" .002-.005" .05-.13mm .13mm .05-.15mm U .005-.012" .005" .005-.010" .06-.25mm .13mm .08-.25mm
24th Sep 2012, 03:40 PM #13.
- 6,459
Thank you Gavin,
It looks like it comes down to how much you are prepared to pay to minimalise variation. M should be cheaper than G.
Bob.
24th Sep 2012, 04:15 PM #14
26th Jun 2013, 08:22 PM #15Diamond Member
- Sydney, NSW
- 1,249
HI Big Shed,
How'd you go with your purchase? What size did you end up getting? Is it worth the money? I only ask as it's my birthday tomorrow and I'm trying hopefully get one for my Hercus 260.
cheers Ben.
tool holder id
By azzrock in forum METALWORK GENERALReplies: 10Last Post: 8th Dec 2011, 03:25 PM -
Diamond Tool Holders - AGAIN
By eskimo in forum METALWORK GENERALReplies: 9Last Post: 3rd Oct 2011, 11:51 PM -
Diamond Tool Holder
By Stustoys in forum METALWORK GENERALReplies: 151Last Post: 15th Sep 2011, 01:57 PM -
tool holder
By glenn k in forum THE HERCUS AREAReplies: 5Last Post: 17th Apr 2009, 03:50 PM -
Diamond tool holder
By Pete F in forum THE HERCUS AREAReplies: 22Last Post: 9th Dec 2008, 08:27 PM
