Results 1 to 15 of 46
Thread: clean up bench grinder wheels
22nd Jul 2012, 05:03 PM #1
made the mistake of grinding some aluminum with the bench grinder and one of the wheels in particular is loaded up with ali and not cutting\
what is the best way to clean it up?ray c
dunno what's more fun, buyin' the tools or usin' em'
22nd Jul 2012, 05:10 PM #2Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Personally I would bin it. You can't clean it properly and it's potentially dangerous. They're cheap to replace.
22nd Jul 2012, 05:14 PM #3Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Could you dress it.
Phil
22nd Jul 2012, 05:21 PM #4
22nd Jul 2012, 05:51 PM #5
You should be able to get a plain dressing stick which is pretty low tech. Things like star wheels are good but expensive.
22nd Jul 2012, 06:02 PM #6
Plain dressing sticks are ok, but I get big diamond wheels that are nearly spent from a concrete cutting mate and cut the wheel into wedges. Each wedge still lasts for ages despite there being only 1mm or so of diamond left. I don't see why you couldn't even buy a cheap diamond cutting wheel and use that.
22nd Jul 2012, 06:26 PM #7
22nd Jul 2012, 06:31 PM #8Banned
- Feb 2012
- 73
- 153
Exploding grinding wheels and ally milk bottle cap welding
I did hear stories of grinding wheels (used to grind ally) exploding when I was working in the shop. It may have come from the same source who saw someone welding ally milk bottle caps, but you never know,!!! Diamond grinding wheel dressers are available on ebay for around $17 or you can get a single point dresser from China for $5.50, they're very quick and do an excellent job.
22nd Jul 2012, 06:57 PM #9Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
I didn't have any luck trying to dress ally out of a grey wheel with one of those black sticks. Maybe I did it wrong. Or maybe my heart wasn't in it because of the stories about exploding wheels.
22nd Jul 2012, 07:16 PM #10Most Valued Member
- Sep 2011
- Ballarat
- 3,103
22nd Jul 2012, 07:45 PM #11
Something like this. You push it onto the wheel whilst under power to clean the wheel face. Auminium heats up and can cause the wheel to fail. It can also put the wheel out of balance, increasing the likelihood of failure.
Carba Tec also sell a dressing tool.
22nd Jul 2012, 07:53 PM #12Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Thanks Groggy,
for the life of me I couldn't find a pic.
Phil
22nd Jul 2012, 07:59 PM #13Most Valued Member
I've got one of those grey dressing sticks. The stick wears down faster than the white ALOX wheels. Is that normal? I find it impossible to get a nice square edge on the wheels because the stick is constantly changing shape. Rapidly moving the stick from side to side helps, but the result is still dodgy.
22nd Jul 2012, 08:00 PM #14
Just bin it and learn from your mistake.
As stated above they are not expensive,
And the piece of mind would make you much
Happier to use the grinder.
Just my .2c worth.
MattWarning Disclaimer
22nd Jul 2012, 08:15 PM #15Golden Member
- Mar 2010
- Nth Qld
- 687
I binned an 8 inch wheel after my brother ground aluminium on it: one of a long line of broken power tools. I used a silicon carbide dressing stick but it seemed to slip over the aluminium clogged area and removed wheel material from the unclogged area, it got increasingly unbalanced until I gave up and tossed it.
Adapting cup wheels to a bench grinder
By Bryan in forum METALWORK GENERALReplies: 28Last Post: 25th Dec 2011, 06:22 PM
