Results 1 to 5 of 5
Thread: Colchester Bantam
27th Jun 2012, 07:17 PM #1
Colchester Bantam
Hi
I could have bought one of these recently..a Mk 1 long bed version in good condition , but without much tooling or accessories . It ended up selling cheap , under $1k .
Does anyone here use one ? I've read that the cost of accessories for these lathes is rather exhorbitant eg steadies and other bits .
Mike
27th Jun 2012, 08:48 PM #2Golden Member
- victoria
- 499
27th Jun 2012, 09:14 PM #3
auctions
I would peruse your local papers for auctions or clearance sales . At the moment the way the economy is, it isn't worth manufacturing anything here . These older lathes seem to be around in good numbers right now , and affordable . And TAFE's seem to be getting rid of this kind of machinery , why I don't know . I am amazed at the amount of machinery that is not wanted anymore and is just chucked out or considered to be obsolete .
For us hobby types , it's a good time to buy .
27th Jun 2012, 09:50 PM #4Most Valued Member
- Sep 2011
- Ballarat
- 3,103
I have one at work Mike and find it a very capable machine. A bit small for what I have to do hence the purchase of the Servian Brunswick lathe. Smooth as silk to use and at the end of the day it's capabilities are only limited by your imagination.
Phil
27th Jun 2012, 10:09 PM #5Golden Member
- Mar 2010
- Nth Qld
- 687
I've got a short bed version I'm in the process of setting up in the shed, a long bed version is so much more useful, by the time you have a D1-3 adapter on a 3 jaw chuck there's not a lot of room left between centres. Do you know if it's the metric or the imperial version?. You'll be able to buy third party chucks and toolholders etc., as well as fabricate a steady for it. I just swapped the motor over for another so I can run it off an inverter as the original two speed motor would be a nightmare to make into a delta wired motor.
Colchester
By pjt in forum METALWORK GENERALReplies: 18Last Post: 8th Jun 2012, 02:38 PM -
Colchester Bantam lathe cheap
By welder in forum METALWORK GENERALReplies: 5Last Post: 9th Nov 2011, 02:22 PM -
Bantam Topslide Travel
By electrosteam in forum METALWORK GENERALReplies: 1Last Post: 17th Sep 2009, 09:24 AM -
Colchester for sale
By rusty steel in forum METALWORK GENERALReplies: 1Last Post: 12th Oct 2008, 08:15 PM -
Colchester
By footz in forum METALWORK GENERALReplies: 18Last Post: 1st Oct 2008, 10:42 PM
