Results 1 to 8 of 8
Thread: Advance Lathes
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,514
    Default Advance Lathes
    I have an Advance lathe. Quite a bit of restoration done but neglected recently, so decided to do some more work on it. Just got a question about the Tapered Bearing type I have.
    Has anyone elso got one? Never seen another since i got this one. Seen many plain bearing types. Is the one I got that rare?
    Nev
    Oct 2008
    blackburn vic
    297
    Hi Nev
    The one I used to have had plain bearings. It also had about 1mm play in the headstock but it enabled me to learn the basics of lathe use. Sold it to a mate who is still using it.
    Roger
    Mar 2010
    Nth Qld
    687
    My Advance is one of the later ones after the maker retired and sold the business, it's plain cast iron bearings with ball thrust bearings to take the sideways load. Can you post some photos?.
    Nov 2008
    70
    1,514
    Lathe is still in pieces. A fair bit of the parts have been cleaned up and repainted but bed is still bare. I'll post a pic or two of the bed tonight if I get around to it.
    Curious to know if anyone else has the Tapered Bearing type and maybe even when it was made.
    Nev
    Mar 2010
    Nth Qld
    687
    Well if the bed has a serial number on the end that starts with "AS" then it was made after Bert Kirby sold the business to Alfred Steward Ltd. in 1962.
    This one had a beefier headstock casting so it's probably tapered roller like yours: The Advance Lathe
    These two are plain metal bearings for sure with a smaller headstock casting like mine: Advance Metalworking Lathe
    More here on them: Page Title
    Nov 2008
    70
    1,514
    Yep same as first link. Forgot I had that bookmarked so that makes two I know of. Has a serial number, but will have to check again as i can't remember what it is right now.
    Nev
    Mar 2010
    Nth Qld
    687
    Same as what first link?. It's the same as the lathe in the first link??, so that'd make it 1970's or so.
    Nov 2008
    70
    1,514
    Quote Originally Posted by Graziano View Post
    Yep this link -
    The Advance Lathe
    Nev
