Results 1 to 14 of 14
Thread: milling vise
24th Apr 2012, 07:04 PM #1Golden Member
- Nov 2005
- adelaide
- 597
milling vise
went shopping for a milling vise and found this 120mmx210mm swivel
no name but it looks interesting and i paid for it
they have 1/2 a dozen BIG shaper vises there to ( too big for me)
i wonder if any one knows what make it is
it looks like the end jaw is reversable
john
24th Apr 2012, 07:26 PM #2
Nice vice...
I have no idea of the make, But I am sure it will provide many years of service for you.
MattWarning Disclaimer
24th Apr 2012, 07:36 PM #3Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
HI,
Looks like a Good Vice, I don't know the Brand either. Your Vice has some similarities to this Vice V311 | Modular Machine Vice | machineryhouse.com.au .All The Best steran50 Stewart
24th Apr 2012, 07:40 PM #4Most Valued Member
Hi John,
Looks good
Looks like the fixed jaw can slide on the swivel base? that could handy............ I dont have one of those
Also can you take the fixed jaw off and then clamp the slide vertically on the swivel base? and it looks like you can clamp it on its side to the table.
StuartLast edited by Stustoys; 24th Apr 2012 at 07:47 PM. Reason: spelling
24th Apr 2012, 07:42 PM #5Golden Member
- Nov 2005
- adelaide
- 597
yes steran it looks very similar to your link with the addition of a swivel base the price tag makes me feel much better for what i paid for
john
24th Apr 2012, 07:53 PM #6Dave J Guest
Great score,
I talked Eskimo into getting one like that from Asset, the only trouble was the price jumped from $550 to $900 by the time I wanted to buy one, LOL
I think his has springs that hold the jaws up a little and the holes in the jaws are slotted, so it has a pull down action when you tighten it up.
Dave
24th Apr 2012, 08:18 PM #7Golden Member
- Nov 2005
- adelaide
- 597
hmm thanks for the replies i think its a bit of an over kill for my rf25 but hey its mine now
its outside under a rug for the night so ill have to wait till daylight to see what happens when i pull it to pieces( for cleaning purposes only)
any more replies welcome
john
24th Apr 2012, 11:12 PM #8Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
John it looks a nice bit of gear but how do you bolt it down? I can't see any holes in the base.
24th Apr 2012, 11:18 PM #9
Thats a nice looking vice, should be very handy. I like the fact that the screw is towards the top half of the jaw. This should stop the jaw lifting.
Nicely spotted Bryan, maybe Hope and good faith holds it down?
24th Apr 2012, 11:43 PM #10Most Valued Member
24th Apr 2012, 11:54 PM #11Dave J Guest
I would be taking the base off it, but thats me.
These vises are held down by little hold down lugs like the small vises you buy, and they go into the slots on the sides. They are a sort of L shape laid on it's side. Maybe the base was designed to use the same clamps as you would have them already for the vise.
Dave
25th Apr 2012, 09:32 AM #12Golden Member
- Nov 2005
- adelaide
- 597
well spotted Bryan it wasn't till i got it home i realized that there isn't any slots but Ive got a set of hold down clamps that will do the trick . its going to be a squeeze cos the foot print of the base is almost as big as the mill table
just goes to show you should look past the shiny bits before buying but im sure i will make it work.if necessary i can always remove the swivel base if not i bet theres a few buyers lining up for what i paid for it
might pull it to bits today for cleaning and see how it works
john
25th Apr 2012, 02:04 PM #13Golden Member
- Nov 2005
- adelaide
- 597
after a cleanup nothing damaged or broken
25th Apr 2012, 07:21 PM #144-6-4
- Mar 2009
- 260
Vice
Greetings Chaps, I used a vice with a similar fasting method for the movable jaw, ie the half round holes in the base. This was at Nestles where I worked on Xmas Shut downs. it looks similar but the one I used was the best vice I have used. On this one the fixed jaw could be removed and another shaped jaw fitted. The fixed jaw was keyed and screwed so there was little chance of it moving. If I had this vice and the mill on which it went would allow it, I would make a sub table with the conventional bolt down screws and a key slot for positioning it on the table. The sub table would only need to be about 1/2 inch plate wash ground. This would remove the need to square the vice each time it went onto the table. What do you think. Yours 4-6-4
How to mount a vise to a lathe for milling
By Bryan in forum METALWORK GENERALReplies: 44Last Post: 18th Aug 2010, 09:47 PM -
Suitable QCTP and milling vise
By Tiger in forum METALWORK GENERALReplies: 4Last Post: 18th Mar 2010, 07:34 AM
