Results 1 to 11 of 11
Thread: Tail stock trouble.
19th Apr 2012, 02:53 PM #1Old Fart (my step daughters named me)
- Sep 2010
- Mallala S.A.
- 75
- 50
Tail stock trouble.
Gents, being new to this please be kind.
I purchased a new lathe Metal master SM-920A.
My problem is I can not get the tail stock to tighten.
If I take it off and tighten underneath it will not slide back on to the bed. If I keep it loose enough to slide back on to the bed it does not tighten up enough in the middle of the bed.
Is there a trick to it or have I got a lathe made on a Friday and the bed is not the same thickness along its length?
You assistance is welcome.
Cookie
19th Apr 2012, 03:01 PM #2Dave J Guest
I would say it's a Friday lathe and the bed underneath is not true to the top.
Some guys convert theses lathes over to camlock to do away with the spanner.
Dave
19th Apr 2012, 06:32 PM #3Turning useful pieces of steel into scrap metal.
- Jun 2010
- Riverina, NSW, Australia
- 68
- 138
Try tightening the adjusting nut with the tailstock on the bed. You might have to use a socket and extension bar with ratchet. Just keep nipping it up until you get the correct position of the tailstock locking lever.
22nd Apr 2012, 07:59 PM #4
23rd Apr 2012, 01:24 AM #5Dave J Guest
My mistake, I thought it wasn't cam lock.
Lather, a spring under the tail stock on the bolt will keep it from grabbing.
Dave
23rd Apr 2012, 02:01 AM #6Old Fart (my step daughters named me)
- Sep 2010
- Mallala S.A.
- 75
- 50
The bolt under the tailstock is recessed and can not be tightened with a spanner, you have to turn the locking plate to do adjustments. What I am thinking might work is place a shim in the recess and expose the nut so it can be tightened. What will cause problems there is the cross members on the bed will get in the way a fair bit. Failing that who knows??
23rd Apr 2012, 07:42 AM #7Most Valued Member
- 4,887
Have you measured along the length of the bed to determine how much variation there is?
25th Apr 2012, 12:32 PM #8Old Fart (my step daughters named me)
- Sep 2010
- Mallala S.A.
- 75
- 50
All measurements taken and given to supplier. Still awaiting their reply. Maybe one day they will reply.
25th Apr 2012, 02:25 PM #9Dave J Guest
I measured my tailstock way for Lather and I have 0.05mm difference (which is nothing) end to end over the bed. My lathe is a 900 between centres Chinese lathe.
Dave
25th Apr 2012, 03:25 PM #10Golden Member
- victoria
- 499
25th Apr 2012, 03:40 PM #11Dave J Guest
If you have a mill or a milling attachment for the lathe, you could make up a new clamping plate.
Dave
Separating tail stock
By ausdag in forum THE HERCUS AREAReplies: 2Last Post: 10th Oct 2009, 07:00 PM -
Macson lathe tail stock
By britannia in forum METALWORK GENERALReplies: 0Last Post: 2nd Apr 2008, 08:16 PM
