Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    Dave J Guest
    Heavier oil might do the trick, you would have to give it a try.
    With the quill drop I have heard a few people talk about this. On my mill (HM52) there is a clock spring which is adjustable for the rack gear. I have mine set up to raise the quill if I let go of the handle. This way the quill is always pushing back on the rack and doesn't drop at all.
    Without this adjusted I could see where the quill would drop, so if you have the spring, give it an adjustment. Mine has 2 holes in the out case after taking the chrome cover off and has a screw under the head which locks it in place. I place a small allen key in one of the holes while undoning the screw and then rotate it anti clockwise for mine to put more tension on it.
    Dave
  2. #17
    Feb 2011
    Mornington Peninsula
    183
    Dave
    Thanks Dave
    Yes I have played with the tension spring and it works where the rack and pinion is working more or less ok.
    However. This may not be the best explanation but there will always be a point where the whole mechanism plays catch up and drops over 1mm. Nothing can really stop that. It's almost like a tipping point.
    My pinion seems to force the quill across to some extent so there is a limit of how much tension would allow the quill to return unaided.
    Of course you don't need to use all the travel but the tension is such that it works over a partial range. If the spring was tensioned enough to return at full extension it would require more preload than I could wind on.
    I messed around with preload using a big lump of high density foam and found that there was still parts of the travel that no amount of preload would improve. You would still get a "step change".
    Justin
  3. #18
    Dave J Guest
    Interesting as I don't have that problem at all, I posted my setup over in the other thread.
    Dave
  4. #19
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Just a thought - that clunk - have you checked the fit of the keys in shafts to handles, pinions etc? It sounds like back lash of some sort, where when a shaft gets to a certain rotational point gravity means that something is pulled forward rather than pushed back. (I would hope that keys are being used rather than grub screws)
    Another cause of the jump could be a missing tooth on the pinion or rack, but that would be far more than a mm.
  5. #20
    Dave J Guest
    I thought I would post it here as well, since it's to do with this mill and not cutters.
    On my mill, on the opposite side of the head to the fine down feed the shaft from gear comes through the head and there is a clock spring on the end of it.
    Do your mills have something like this, if not this is the problem with the quill dropping.
    Dave
  6. #21
    Dave J Guest
    After looking at the grizzly parts manual below, I see it is the same set up as mine with the clock spring.
    http://cdn0.grizzly.com/partslists/g0519_pl.pdf
    I also checked the slop between the rack and gear and mine has about 0.5mm movement up and down at the quill. My quill is heavy enough to fall on it's own, by the sound of it your quills are getting hung up on something. I also grease my quill to help with some of the play, and even with that it drops down no problem.
    For mating the gear to the rack better, I do have pictures etc of one guys method where he bored the head casting to take bushes, and then he bored the bushes off set to give adjustment of the mesh of the gear. This will only work if the gear will mesh with the rack without and play, so you would have to do a bench test to see what it's like.
    The only other thing I can think of is to place a spring on the quill to help hold it up. This would stop it dropping down.
    Dave
  7. #22
    Sep 2007
    Newcastle NSW
    77
    155
    Hello Jarh73,
    I have explained my solution to this problem before but at the risk of boring everyone here I go again.
    On my mill (Zay7045FG/2) the play is between the Quill rack and pinion, as on other machines. I found that when I released the Quill clamp, the two cast iron slugs which pressed against the Quill did not release immediately, but when I started to lower the Quill the clamp released which caused the Quill to drop and produce the "clunk" sound. I turned the ends of the two "slugs down and pressed brass end pieces onto them. I now keep the Quill clamp nipped up slightly and the brass end pieces do not grab onto the Quill and do not score the Quill surface. I also replaced the grub screw which locates in the slot down the side of the Quill, with a bolt with a phosphor-bronze end piece, and I keep this tightened slightly also. I don't have any problems with the quill dropping now . I have fitted a vertical digital scale to the Quill which I think is necessary to show exactly how far the Quill has moved .
    Russell
  8. #23
    Feb 2011
    183
    Quote Originally Posted by rusty steel View Post
    Hello Jarh73,
    Russell
    I'm fairly sure I know what you mean.
    Did you have any pictures handy or a link to your solution?
    I have had the odd problem of changed height of quill when it's undone.
    On another note the leak is fixed for the moment.
    Justin
  9. #24
    Dec 2008
    NSW
    7
    Hello
    I just started a new thread about this machine and now I found this.
    Does anyone know how to get the top open? I want to clean it out and replace the seals.
    Motor is off, 6 top screws are out and top can lift 25mm.
    No more.
    What am I missing?
    Bernt
  10. #25
    Oct 2018
    Hazelbrook, NSW, Australia
    1
    I have just become a member of Metalwork Forums. Spent 20years as Fitter/Machinist, and other pursuits, before retiring. In relation to the HM-46 Mill Drill, the Men's Shed I belong to purchased a one with digital readout, coolant pump etc. My experience with the machine was that the difference between the graduations on the find feed dial and the actual amount removed is .020 inch with the lock lever on, while the digital depth reading would change .002 inch once the lock lever was put on.
    The machine would also chatter under a heavy cut. On investigation on a few forums, the problems seemed to be no vibration absorbers fitted, and the HM-46 does not have the option of an R8 taper, only a Morse taper. Morse taper okay for drilling, but R8 taper is better for milling. A company from Melbourne sells a Metex DM45 with an R8 taper, and from what I have read, everyone that has purchased a DM45 is very happy, and not reporting the problems of the HM-46.
  11. #26
    Aug 2012
    Australia
    645
    Quote Originally Posted by Ashley E View Post
    The castings are the same between the DM45 and the HM46. It’s just the brand name that’s different. The reason you’re not finding bad reviews is likely down to the fact that H&F have sold a heap of them and all the rest sell a much smaller volume.
    I happen to own an R8 45 and have plenty of complaints. If used within their limitations they can serve a purpose.
  12. #27
    Jun 2011
    Australia east coast
    2,713
    Quote Originally Posted by variant22 View Post
    I seem to recall you had about the same contact area on the slides on a brand new machine as I did on a 70+ year old Monarch lathe.... scraping is such fun
    They make really good heavy duty drill presses with a built-in X-Y table. As milling machines, not so great. We had one at work, bought it to keep the electronics techs away from the good machines.
    PDW
  13. #28
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    I have posted this in the past, but I haven't been back on the forum in a long time. Here's a link that should help http://www.graetech.com/index_files/Page878.htm and the PDF version which I got from somewhere that I can't find now anyway I just up loaded it here http://www.filedropper.com/rf-45millheadrebuild
    I hope it helps.
    All The Best steran50 Stewart
  14. #29
    Dec 2008
    NSW
    7
    Still, for the price, it is a reasonable machine. Since posting about the problems with the oil leaks and non concentric grooves for O-rings on the shafts, I have had no issues with the machine.
    Ok, I do not use it a lot but I have machined several large gears and other stuff on it without issues.
    The Z axis is not the best and needs to be lock lever needs to partially lock to create friction so avoid uncontrolled downward jumps when turning the handle.
    Bernt
  15. #30
    Jan 2015
    Newcastle
    5
    Hi I only recently acquired my HM46, very happy with it, the clunking noise, I think come from the quill return spring, I heard that noise straight off from using my machine, when using the down feed handle
    sorry read further on all the same track
  1. Problem With a Hafco HM-46 Mill/Drill.
    By Jarh73 in forum METALWORK GENERAL
    Last Post: 23rd Jul 2012, 11:51 AM
  2. hafco mill collant setup help
    Last Post: 20th Feb 2010, 09:55 PM
