Results 136 to 150 of 941
Thread: What did you learn today?
13th Apr 2013, 07:55 PM #136
What did I learn today?
I learned that while my super dooper expensive Stick/Tig welding inverter unit has many and varied bells and whistles, that the automatic doohickey (AKA as a solenoid) didn't do its stuff when I forgot to turn off the cylinder valve.
Its a lesson that will cost me over a $100 to learn.
14th Apr 2013, 12:22 AM #137Most Valued Member
14th Apr 2013, 07:52 AM #138Senior Member
- Newstead Victoria
- 459
Good morning,just read through the hard road lessons.I used to have apprentices once who used to leave gas turned on.Next day no gas.Off to local CIG now BOC for a refill.Used to educate them to wind out regulators at the end of a welding session gas can only get out if regulator is crook.Still used to check every night and shut off the bottles.
By the way just got BOC a/c for 3 bottle rental e size 1oxy 1 acetylene 1 argon. 573 dollars is becoming outrageous and a luxury item,let alone what gas value is in them.I dont weld or need the hot spanner every day but am always grateful that resource is here.
In the 50's here the local garage owner charged 1 pound just to light the torch.
I tend now to list my welding jobs and do them as a lot just to economise on gas usage.
Just asking here if other members feel the way i do about the hi bottle rental.
I do travel to South east Asia and spend the winter months there for the past 7 years and note over there the price of gas and rental is what we would say is cheap 20 dollars for a g bottle of oxy.they do lots of gas welding there and thank god for the invention of d bar reo rod every thing gets fixed with that seen ladders crow bars even hack saw frame made from it.
Checking the other day the local Air Liquide agent is offering 1 yr free rental on bottles.does make you wonder about the ''other gas company.
Cheers John
14th Apr 2013, 08:47 AM #139Most Valued Member
- Australia east coast
- 2,713
I think it's outrageous. As soon as I finish my boat the Argoshield cylinder is going and I'm switching to CO2 which I can buy outright.
There's a company in Sydney selling cylinders & gas (or was) and I'm going to buy an E cylinder of Argon, bring it back here with me. I don't use a lot, just for TIG welding so it'll last me more than enough time to just write off the bottle if I have to.
I don't do much oxy cutting since I got a plasma cutter and a friend is in the dive supplies biz so I can borrow a bottle of medical oxy off of him if I ever need to.
PDW
14th Apr 2013, 11:55 AM #140Most Valued Member
As I understand it we are being bent over something shocking*.
My last invoice for 12 months rent on an E size bottle was $190.34.
Last I heard Speed Gas in NSW(and southern QLD) is selling full D size for $339.
Anyone got a recent price from speed gas?
I use argosheild 54 which speed gas dont have.
*of course if I dont like it and think its so easy, I could always start my own gas company
14th Apr 2013, 11:27 PM #141
What did i learn, well, yesterday?
I have the Mars running again and did some test cuts etc. I was wearing long sleeves and absently wiped my mouth on my sleeve only to feel a nasty sharp pain across my top lip.
There was a shaving on my sleeve......it sliced my top lip open from end to end. The worst part was it wouldn't stop bleeding.......
Lesson learned......i hope1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
15th Apr 2013, 09:39 AM #142
Just reading the price of Gas bottles these days I still have my Colt oxy kit and even tho they are small bottles there is no way I could even consider the outlay.
17th Apr 2013, 01:30 AM #143
I learned that I don't have any left handed boring bars.... never realised I'd need one... Josh was boring a 6" hole in a cast iron block, and needed to mount the boring bar horizontally, which means you need a left handed boring bar, since you can't run the mill backwards, the boring head would unscrew off the arbor..
Ended up brazing a bit of carbide upside down on a right handed boring bar (after slight modifications with a high precision angle grinder.. )
Moral of the story, get left and right handed versions when buying boring bars...
17th Apr 2013, 06:33 AM #144Most Valued Member
- Sep 2011
- Ballarat
- 3,103
I learnt today that you should not store the plastic container with the clip on lid full of brick and paving cleaner in your shed, and if you do then don't store it on your pigeon holes that you made and mounted to the wall. If you must then make sure the pigeon holes are attached to the wall a lot better than you should have but if you can't attach them a lot better then make sure that a bloke doesn't come and do the spouting on that wall and start banging the wall with a hammer. Otherwise this could happen. It is amazing how much 'flight' rust I have on everything now.
Phil
17th Apr 2013, 08:51 AM #145
Makes me wince.
Sorry to see it has happened.
Is "Brick and paving cleaner", hydrochloric acid?
Would an alkali or buffer neutralise it. Ie sodium bicarb? Lots.
Chemistry was not one of my strong points so open to higher wisdom.cheers
David
A society grows great when old men plant trees whose shade they’ll never sit in. (Greek proverb)
17th Apr 2013, 11:39 AM #146Dave J Guest
17th Apr 2013, 11:41 AM #147Dave J Guest
17th Apr 2013, 12:42 PM #148Senior Member
- Newstead Victoria
- 459
Baking soda washing soda diluted in tank water put in in a garden sprayer to stop the acidic etching presume spirits of salts.muriatic acid or hyrochloric acid all the same was the paving brick cleaner. then wipe dry and treat with a grease pet jelly or vaseline or any light grease can use dwf wd 40 crc to absorb water or lanox i like lanox products as is natural wool fat lanolin available as a grease as can [aerosol] most important thing after treatment is to put a barrier between the moist air and contaminated object .Knowing good old Ballarat weather this time of yr is similar to here and lots moisture in the air overnight.Sorry to hear of your dilemna and know the feeling well,when the courting season with my pet possums here do the business in the shed. separate the acids the paints and the inflammable.Put them in cabinets. John.
17th Apr 2013, 01:52 PM #149Most Valued Member
- Charlestown NSW
- 1,669
Interestingly, according to wikipedia (so it must be true) BOC was taken over by Linde Gas in 2006. The BOC Group - Wikipedia, the free encyclopedia
Also, according to wikipedia, Air Liquide took over Linde Gas UK in 2007 Air Liquide - Wikipedia, the free encyclopedia
I don't know if that means BOC here is actually owned by Air Liguide or not but it wouldn't surprise me. They have us over a bottle, so to speak.
Does anyone know anything about low pressure Acetylene generation using a generator and Calcium Carbide? ( I think thats the material). I'm assuming thats how it was done back in the day before high pressure set ups became the norm. They used to use it for lighting on early cars etc.
I have an old, small, hand held carbide light that someone gave me when I was a kid that I would like to try and restore one of these years. Its only a cheap asian made thing.
bollie7
17th Apr 2013, 08:17 PM #150Member
- Apr 2013
- Karana Downs QLD
- 78
Hello bollie7, You have raised two interesting issues. I have a 1800's 'Magic Lantern' passed to me by my grandfather. It uses a Carbide Lamp as well - but that's the part that's missing. It was replaced with a 60w incandescent probably in the 30's or 40's. But my old Pop told me that it had a controllable water dripper to add the correct amount of water to the carbide rock in order to get the amount of Acetylene needed. But you mentioned this because we would all like some welding fuel that's cheap.
Well don't tell the 'woodies' this, but cooked wood (dare I say 'timber'?) also produces a good fuel gas as does charcoal. Both my Pop & Dad regaled me with many funny yarns from the 'between the wars' years and beyond about the life experiences they had making and using gas producers to run cars, tractors and pumps. In my youth, I spent a lot of time making charcoal for my Dad (a traditional Blacksmith). Mallee stumps make the best charcoal.
Yours in (Fuel) gas producing!! Daryl
