Results 1 to 15 of 36
22nd Mar 2012, 10:09 AM #1Most Valued Member
Epoxy Granite. Has anyone used it on their machine?
Hello all,
I have from time to time read about epoxy granite and using it to fill machine voids to increase mass and rigidity. Most of the discussions have been on other forums, forums that I am not a member of and know little of the members. In these other forums, much has been discussed about the improved dampening properties and so fourth but I have also read other members saying that it is a furphy and nothing is really to be gained. Some of the discussions get quite technical and way above my basic knowledge of material science.
I have done the usual search on this fourm and little has been discussed. Has anyone attempted such a project and if so, what were the results? If so, what ratios and ingredients did you use? I'm really interested to know. I don't have any immdeiate intentions to take this on as a project but I'm still interested in what people here have to say.
22nd Mar 2012, 11:27 AM #2Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
is this something like chock fast?
aaron
22nd Mar 2012, 11:59 AM #3Member: Blue and white apron brigade
Epoxy granite only has the same approx density as Aluminium so you need to add a lot of it to a machine to make any significant gains and given the cost seems like it would be an expensive way to go.
If you really wanted to increase mass you would be better off using something like regular epoxy to attach slabs of lead into machine voids.
22nd Mar 2012, 12:10 PM #4Most Valued Member
22nd Mar 2012, 12:11 PM #5Most Valued Member
22nd Mar 2012, 12:35 PM #6Member: Blue and white apron brigade
In terms of vibe and rigidity, if you increase the mass of any vibrating system you will dampen vibration and increase rigidity so gluing lead into void will still have the same effect. Being soft (ie it does not ring when struck) and heavy, lead has excellent damping features. However it has poor thermal expansion properties (twice that of iron) so it would be worse from this aspect.
The Wikipedia entry for it has some interesting info about epoxy granite. Apart from significant gains in natural vibration damping over cast metal, the big benefits seem to be more in energy savings of production and in very low thermal expansion, but it seems to me that the latter would really only apply if the whole machine base or component is made from the stuff. Just gluing some into cast voids is unlikely to change the thermal expansion properties as the original casting will tend to dominate that aspect of the machine.
Talking about damping reminds me of an electronic amplifier that we had that we were using to detect femtoamp signals. Even though it was set up on an optical vibration isolation table the amplifier could easily detect people walking past in the corridor and a slamming door set it right off the scale. In the end we placed 4 lead bricks on the optical table and that was enough to dampen out the effect of people walking past (but not the slamming doors).
22nd Mar 2012, 12:52 PM #7Philomath in training
Bob, this stuff is poured in like concrete. I think there was a write up in MEW some time ago by a guy who filled is X1 column with the stuff.
However, to respond to the question asked, as Bob says it will dampen vibration. For large machines I would not bother as I suspect the benefit would not really be noticable. For a 'mini mill' there may be an advantage. If you filled a column with it it will make it slightly more rigid although you then have to contend with flex in the head and table, so it won't mean you can take heavier cuts but the finish on the cuts you do take may be a little better.
Think of it this way - vibration from a source has energy. Increasing the mass will mean less energy per unit mass, so the physical effect of the vibration (movement) should be less. (Should because if you hit a resonance the vibrations are amplified)
22nd Mar 2012, 02:12 PM #8Most Valued Member
- Oct 2010
- 1,910
really
well Simon you'd know.
but any way its a epoxy grout. that is very strong.
you poor it in and has High tensile strength, compressive strength,
flexural strength, creep resistance and superior vibration damping
so the advertising says any way.
basically a marine grout that goes between a non machined engine bed and the engine.
ITW Chockfast Marine | Epoxy Grouts, Adhesives, Repair Products, Coatings
22nd Mar 2012, 02:59 PM #9Member: Blue and white apron brigade
Chockfast has a density of ~1.8 g/cc whereas granite epoxy has a density of 2.7 g/cc (about the same as aluminium so I doubt they are the same thing.
22nd Mar 2012, 03:47 PM #10Most Valued Member
22nd Mar 2012, 04:06 PM #11Golden Member
- May 2003
- 526
There is a lot of discussion on this at CNC zone.
Here is an article of a HM45 mill having it poured in the voids. The CNC cookbook blog is a good site for milling and lathe articles.
I am with Bob on this one and a heap of lead will dampen the majority of vibrations.Cheers,
Rod
22nd Mar 2012, 04:42 PM #12Member: Blue and white apron brigade
22nd Mar 2012, 04:56 PM #13Most Valued Member
22nd Mar 2012, 05:46 PM #14Golden Member
- May 2003
- 526
Hi Simon,
I thought the same but I would like to hear the opinions of a few before I did it. I also wonder about the longivity of adhesion when stuck to a disimilar material.Cheers,
Rod
22nd Mar 2012, 07:41 PM #15
Some woodworking equipment has had slabs of reinforced concrete bolted into the chassis for the same purpose. Others have had it poured in place, but it is a special mix, the details of which are unknown to me.
I like the idea of lead ingots bolted in, or depleted uranium if you can get it locally.It's all part of the service here at The House of Pain™
