Results 1 to 3 of 3
    Nov 2008
    Perth WA
    6,459
    Default Sandvik Coolant Fed Drill Bit Puzzle
    Saw this at a second hand tool shop this morning and was intrigued. Can anyone suggest how they created the coolant passage ways inside the spiral flutes? There are two inlet holes at the rear end of the bit.
    BT
    Jul 2011
    Melbourne Australia
    1,376
    Bob.
    I have it in the back of my mind someplace that they drill straight holes through the shank, then hold both ends, and induction heat them and put the twist in. Then creep grind the flute’s .
    Phil.
    Oct 2002
    Central Coast, NSW, Australia
    60
    98
    Googling from Phil's comment, I found this
    :: FORECREU ::
    Andrew
  1. Anybody here running Sandvik Capto tool holding system?
    By Greg Q in forum METALWORK GENERAL
    Last Post: 4th Feb 2012, 11:13 PM
  2. Using Coolant
    By simonl in forum METALWORK GENERAL
    Last Post: 22nd Dec 2011, 10:11 PM
  3. Sandvik carbide scrapers
    Last Post: 17th Jun 2011, 12:14 AM
