Results 1 to 7 of 7
Thread: Transfer punches.
16th Mar 2012, 04:11 AM #1Senior Member
- Salem Ohio
- 219
Transfer punches.
Where i work we have holes larger than 1/2" that need copied onto other plates. Most guys in the shop have the set of transfer punches that range from tiny to 1/2". So i have a box of these little bits of 1" round in my scrapbox and i drill them 1/4" and point the one end to a 45* angle. Takes a few minutes and i pass them out at work to my mates. Just put the tapered end in a hole and hit the transfer punch lightly and wolla a centered hole. Just thought i would pass this along. The larger one with the side hole was cut off an old handle and i thought it looked cool with the rash on the side so i left it...Bob
16th Mar 2012, 09:28 AM #2
16th Mar 2012, 10:24 AM #3Most Valued Member
- Oct 2007
- 3,112
Excellent idea Bob, thanks for posting that. I use the transfer punches you mentioned, the trouble is both metric and imperial sizes are needed. I think your tool would be excellent for general work. The only issue I can see is that when using it on thicker work, if it wasn't held precisely perpendicular the punch mark wouldn't be in the correct location. However I still think your little widget would be perfect for 99% of work.
One thing I would like more sizes of are transfer screws (used to transfer blind holes), so if you wouldn't mind coming up with a solution to that so I don't need to make or buy a whole heap of different sizes that would be terrific
Pete
16th Mar 2012, 10:29 AM #4Most Valued Member
Nice one Bob
16th Mar 2012, 11:31 AM #5Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
great trick
there great . you know on occasions ive used a hole saw to do the same thing with the drill part only sticking out a little past the hole saw. this method is a little rough. i think ill make one just like yours.
thanks aaron.
16th Mar 2012, 09:42 PM #6Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
All
Use a piece of plate steel or sleeve bored to the correct diameter as a holder to keep the coned centre perpendicular.
JohnQ
17th Mar 2012, 08:46 AM #7
Hi Bob,
That's a clever idea, the best ideas are often the simplest
General Purpose 90° Forming Punches and Dies
By RustyCan in forum METALWORK GENERALReplies: 5Last Post: 24th Nov 2010, 09:08 PM -
Transfer screws and Transfer Punches
By Com_VC in forum METALWORK GENERALReplies: 6Last Post: 27th Feb 2010, 09:13 PM -
Number punches.
By lantain1982 in forum METALWORK GENERALReplies: 7Last Post: 18th Aug 2009, 11:04 PM
