Results 1 to 15 of 32
13th Mar 2012, 05:37 PM #1Novice
- 12
Selecting a small Mill / Mill/Drill
Hi All,
I don't post much here, mostly just lurk. I'm looking at purchasing a small mill / mill-drill & would like other's opinions on the subject in general, and specific brands/machines in particular.
A bit about me - I'm a patternmaker by trade, havn't worked in the trade for ~16 years, but I appreciate a good machine - I've operated machining centres with up to 4m beds, and learnt on a Taiwanese copy bridgeport - I wish I could get a machine like that now.....
Anyways.
I'm chasing a machine with ~500mm travel on the bed's X axis - this allows me to work on my Puegeot cyl heads & smaller engines. After this, everything else isn't a big deal. The RF30 style of machine is probably what I'll end up with - but I'd prefer a dovetailed column for obvious reasons, if one fits into my price range / size. A bigger machine would be great, but moving it around will be an issue - the RF30 size seems fairly portable. I'll mostly be facing & drilling alloy & iron castings, and some timber patternwork, with a bit of mild steel milling thrown in.
Price range is about $1500 - which I know will get me a new chinese machine, but I'd probably prefer to hang out for a good 2nd hand Taiwanese machine.
So - Thoughts? If anyone knows a good 2nd hand dealer in melbourne, I'd love to hear about it..... I've found one in a local dealer for ~$1000 that looks good - used mostly for slotting aluminium, so no heavy work.... But I'm not in a rush......
Rob.
13th Mar 2012, 08:24 PM #2
H&F Sale - 22 March 2012
Hi Rob
H&F will be having a sale from 22-24 March 2012. Their HM46 dovetail mill will be going for $1,749 (normally $1,969) with the folowing specs (X) 475mm (Y) 195mm (Z) 450mm (see pg 22). A bit above your price range and a bit less x travel than you were looking for but maybe worth consideration.
I'm also in the market for a larger mill (I've currently got a RF20 and a X2) and am looking at replacing the RF20 with a new or used dovetail mill with a bit more X travel and of course the convenience of a dovetail.He Who Dies With the Most Tools Wins
13th Mar 2012, 08:51 PM #3Most Valued Member
- 4,890
In regards to the dovetail,in other threads I have read that people arent able to take very big cuts with them,they seem to wobble and move,might be something to consider.
Based on what I have read it would appear that the round column mills are a more ridgid set and capable of being worked harder than the dovetail type.
Am not sure if opperator error or experience plays any part in it though.
If by some chance it does it dosent seem to be admitted.
13th Mar 2012, 09:50 PM #4Novice
- 12
Thanks Guys. I too have noted comments about the round-column machines potentially being more rigid, which is interesting.... I guess it comes down to the column.... My old (1979) McMillan drill press uses a cast iron column, the casting is some 10-12mm thick, as opposed to the modern steel tube columns..... It's very, very rigid....
The 500mm+ travel is pretty important to me - it means being able to do the job in one set-up. I agree though, the HM46 would be a nice machine......
Blu-Rock - what do you use the X2 for...... I have to admit, they look like toys to me, but I'm interested to hear about them.... Make a good pattern mill, I reckon.....
Rob.
13th Mar 2012, 10:02 PM #5Golden Member
- May 2003
- 526
The round column can be a pain if your quill travel is shorter than your tooling requirment. eg hard to reposition it if you go from a small drill to a large one and you have to lift the head.
Rod
13th Mar 2012, 10:56 PM #6
Hi Rob, the rigidity of round vs square columns is always an interesting discussion, there appear to be two schools of thought on this one. I supppose that the major variables are the wall thickness of the columns and their external dimesions. Here are two interesting threads here and another here.
The X2 was the first mill I bought, new from an eBay seller. Being a machining virgin, it was a cheap way to get into the hobby. I've used it to make many smaller tools (as you do) and am almost finished making a small, single cylinder 4-stoke engine as well as plenty of other odds and sods. Yes, it's a bit of a toy and lacks both power and rigidity. Nevertheless, I was a good way to see if I wanted to get even deeper into my machine tool fetish.
The X2's weakness is that stalls if you load it up too much and you can only take light cuts when drilling or milling steel. However, it's OK for aluminium, plastics and other softer materials. I plan to CNC it in the future. Like you mentioned, I too reckon it would make a nice little pattern mill. There is heaps of info on the web about CNCing them and this guy takes X2 mods to a whole new level.
I bought the RF20 as part of a deceased estate lot that included a 12"x36" lathe (the lathe was what I really wanted in the lot) and heaps of tools for both the lathe and the mill, as well as a lot of other tooling and materials. The deal was too good to pass up.
The RF20 (it's an older one made in Taiwan) is certainly rigid and I can take some pretty substantial cuts in steel and it has heaps of grunt. Like Rod mentions, the main issue with the round column is maintaining alignment if you have to move the head up or down when changing tools on a setup. There are several strategies to overcome this potential difficulty and there are many threads on this issue. I've read about modifications that can be made to these machines to more or less lock the head from rotating while still maintaining the capacity to raise and lower it. One method involves fixing the rack to the column and another uses an additional outboard column... all good food for thought. Using a laser fixed to the head and shining it on a datum line and other datum methods also are reported to work.
I'm in no hurry to upgrade and would really like to get my hands on a used, mid-sized Bridgeport-style mill with a knee, something about 2/3rd the size of a BP would be ideal.
Good luck with your purchase when you decide to take the plunge and be sure to post some of your work.
P.S. gotta love the Pug... I used to have a 404He Who Dies With the Most Tools Wins
14th Mar 2012, 11:33 AM #7Novice
- 12
Cheers for the feedback all - esp Blu Rock about the RF20 - Obviously an RF30 would be simarlarly useful, just bigger..... I'll investigate the methods of aligning the head - That may well solve the issue for me, not that it would be a big deal for me anyways.... Unlike some people, for whom the machining is the hobby in itself - (and it's a noble hobby!) - for me it's merely a way to complete the work I wish to do..... It's 'Just' another tool for me..... So, rather than scale down the work to the size machine I have, I need to get a machine the size of the work......
Blu - I have 2 404's - one for parts - and my current project is fitting a 2lt injected engine out of a 504 TI, plus 5-speed gearbox & aircon, to the good one..... Great cars.....
14th Mar 2012, 11:56 AM #8
Plus one for Pugs
First car was 1955 Peugeot 203, leather lay back seats, great car.
Graduated to a 404 also a fantastic car for its' time.
Have also owned a few Renaults, a Dauphine Gordini and an R8 Gordini among them.
Company cars from there on in.
Oh yes, subject is mills.
Have a DM45 dovetail mill (similar to HM46) with 2 hp motor, does everything I ask of it, which I guess isn't that much really
14th Mar 2012, 02:09 PM #9Novice
- 12
Cheers, Big Shed!
Just went out to Hare & Forbes, and also Asset Plant & Machinery. Bother decent looking machines, appear to be reasoable quality. The HafCo has 540mm travel & the Assest SM32 has 500, apart from that they're line-ball....... price-wise there's nothing in it. The saleman at Asset impressed me more, though, I have to say...... Not that that's important
While at H&F, the HM46 was sitting next to the HM32... the base & column bolt pattern is the SAME!!!! So, a HM46 column & head would fit a HM32 base/table...... When I raised this with the salesman, he said it MAY be possible as a special order if both machines were from the same manufacturer (they appear to be), but didn't sound keen..... I didn't press him, as I'm still looking around, but when ready to go, I might go & lean on him to investigate...
14th Mar 2012, 02:47 PM #10
Just an observation!!!
You have to give a big thumbs up to the members of this Forum!
Here we have Wombat asking for detailed answer to a question and with in no time at all others have come in with just the details he needs to make an informed decision.
The Forum is such a gem with its knowledge base and experience
To coin a phrase from John Laws I think we all need a big "YEH" for the day.
Good luck Wombat with your search for a new mill. I will be looking on from the side linesJust do it!
Kind regards Rod
14th Mar 2012, 03:03 PM #11Novice
- 12
Hmmmm, perusing the catalogues I brought home......
I think I found my ideal machine!!!
SM-MD45. Mill Drill. Steelmaster Geared Head Drive Mill Drill, Dovetail Guides, Digital Depth. - Asset Plant & Machinery
A bit out of my price range & a smaller motor that the other two, but much more capability & I could always upgrade the motor if I got annoyed by it.......
Ahhh, decisions, decisions.....
14th Mar 2012, 03:20 PM #12Most Valued Member
- Australia east coast
- 2,713
14th Mar 2012, 03:25 PM #13
I bought my SM920V lathe from Asset it was a pleasure to do business with them. About the only thing I could say against their DM45 mill is that it comes with an MT4 spindle, much harder to get tooling for than, say, an R8 spindle.
I bought my DM45 from Standaco in Nunawading, not only did I get the bargain of the year, it was again a pleasure to do business with them and have since bought other accessories from them. Good family business that actuall operates on the basis that customer servce is important not like some that are more like used car dealers. My DM45 came with an R8 spindle and a CMG 2hp single phase motor. I have since acquired a 2hp 3phase motor for it and a VFD so that I will have variable speed. It is however still awaiting installation, too many other things on my plate!
14th Mar 2012, 03:37 PM #14Novice
- 12
Alternating between a collet holder & a chuck, plus probably a face cutter in an arbour. Academic, really, as all machines at this end of the market (or at least the ones I'm looking at) seem to use MT Spindles - mostly 3's
I can always sleeve MT4 dow to MT2 or MT3..... no biggie, really..... I have a fair bit of MT2 stuff already....Last edited by Wombat200; 14th Mar 2012 at 03:40 PM. Reason: extra reply
14th Mar 2012, 04:03 PM #15
Advice on a small Mill
By Woolant in forum METALWORK GENERALReplies: 8Last Post: 4th Apr 2010, 10:23 AM -
Advice on selecting a mill
By krisfarm in forum METALWORK GENERALReplies: 13Last Post: 7th Jan 2010, 02:25 PM -
CNC a small X2 hybrid mill
By rodm in forum METALWORK GENERALReplies: 33Last Post: 12th Apr 2007, 03:15 AM
