Page 1 of 2 12 LastLast
Results 1 to 15 of 24
    Charlestown NSW
    65
    1,669
    Default Richardson Drill Press
    In the thread about moving my mill recently Bryan asked to see some pics of my old Richardson drill press.
    I've had this since about 1975 when my uncle bought it (for $30) from someone who he had bought some other equipment from. At that time it had been stuffed in a leanto out the back of some workshop for quite a few years apparently.
    It originally had 3 step flat cone pulleys and a 3 phase motor on it as well as a rectangular, fixed table. At the time I put a 2 speed washing machine motor on it and fabed the stand out of old gal pipe that dad had laying around, and ran it like that until around 1992-3 when I gave it a rebuild. I had some ex student exercise, cast iron 4 step, M section pulleys which I used. I also fabricated the circular table arm. The table itself is off an old, small, Perkins engine. Also put some shelves in the stand and filled it in. I have no idea how old this thing is but it doesn't even have a spline on the main spindle fro teh drive from the pulley. It uses a sliding feather key. Which as it turned out, was a good thing as it was easy to slightly increase the size of the keyway on the spindle and make a new key when I re - pullied it.
    Its been a great of bit of equipment. The only regret I have now is I didn't keep the original table as at that time I wasn't interested in the historical aspect of the machine. Mind you, the table had been lightened a lot before I got it.
    bollie7
    Jul 2010
    9,088
    Hi bollie7,
    Is this the drill that went after your foot the other day?
    Whats the thing chained to the pillar?
    Is there a bear in the top of the casting above the spindle and pulley?
    Charlestown NSW
    65
    1,669
    Hi bollie7,
    yes
    Its one of those belt sander attachments. Can't think of the name atm. I got it as a birthday prezzie some time ago. Works quite well, but I haven't used it for some time.
    yes. The pulley is mounted on a sleeve with an internal keyway which takes the sliding feather key, bearing top and bottom.
    I just remembered that when I rebuild it I also made a new pinion for the quill feed as the old one was pretty badly worn. Thats when I had access to a fully equiped machine shop after hours.
    bollie7
    May 2010
    Lower Lakes SA
    58
    2,607
    Thanks for the pics, Bollie7.
    Dave J Guest
    Nice looking unit,
    Dave
    Charlestown NSW
    65
    1,669
    These are pics of another Richardson drill that I took a couple of years ago. Its in a workshop here at work. Its a column version with a morse taper spindle and the super low reduction pulley set up
    Nov 2008
    Perth WA
    6,458
    Boll,
    The outrigger motor is unusual, sort of setup the contrary French would come up with.
    You've done a fine job of keeping your Richardson alive. I understand the replacement table thing. When I acquired my 40 dollar Tough, the table was a victim of wanton chain drilling. I couldn't bear to look at it so I found and fitted a Taiwanese table in it's place.
    BT
    Jul 2010
    9,088
    Hi bollie,
    Any idea why they wanted such low speed?
    Is the winch for moving the table or something else?
    Charlestown NSW
    65
    1,669
    I spent about 10 mins last night typing up a big long answer only to lose the lot when I clicked "post reply" grr
    Anyway, as far as I'm aware the outrigger motor setup is original though I'm not sure of the motor pulley has been changed or not. Being a morse taper spindle the lower speed would be needed. Yes the winch is (was) for raising the table. I found it laying in a cupboard years ago so made up the brackets etc to fit it to the drill. It worked fine but since I was transfered out of that dept someone has managed to break the pulley and have never bothered to fix it.
    BT
    Thanks. When I was converting it to use the "M" section belt and pulleys I thought I might have had a problem with smaller section belt slipping under load but its never been an issue. The pulleys were really cheap which is why I used them. I also have another one to make a compound drive up which I hope to get to one of these years. I would also like to make a belt tensioner so I don't have to use the small pinch bar. Again, one of these years.
    bollie7
    Aug 2009
    Armadale Perth WA
    54
    0
    Hi guys,
    Just wondering ... one of my pedestal drills looks just like the one you have at work - except for the motor outrigger ... but it is only plaqued as "manufactured by Sterling Machinery".
    I wondered if this was a kind of knock-off, or re-badging or etc.
    It is kinda neat as, being 3 phase, it has an On-Off-Reverse switch box.
    It has an MT2 spindle.
    Appreciate any info,
    Thanks,
    Paul McGee
    Charlestown NSW
    65
    1,669
    Paul
    Thats interesting, Certainly looks the same. I have no idea what the story is though, unfortunately. Maybe they were made by the same company under different names. A lot of that went/goes on. If I get a chance in the near future I'll see if I can go and have a close look at the label on the one at work, see where it was made.
    bollie7
    May 2010
    Lower Lakes SA
    58
    2,607
    I've been pondering the integral pulley guard, thinking it must make it a pain to work on the pulley or spindle and why would you do that? But it's just dawned on me it must be for an outrigger bearing, which would give a lot of extra support. Can anyone comment in real-world terms on any extra accuracy or rigidity provided by this feature? And is it really a pain to work on?
    Nov 2008
    Perth WA
    6,458
    Default In my opinion
    One of the biggest issues regarding accuracy in a drill press is wear between the head casting and quill. I can't see a way in which the outboard bearing would alleviate that wear occuring between the sliding surfaces unless, in a conventional arrangement, pulley belt load is transfered to the spindle splines. I guess that might occur if the pulley bearing was faulty. The outboard bearing would lessen the possibility of pulley tilting.
    Both my Waldown 3M and Tough have pinch (?) bolts allowing the partial removal of the wear induced play as does the Richardson. Nice features that go someways to keeping the machines alive and well.
    BT
    Jun 2011
    Australia east coast
    2,713
    Quote Originally Posted by Bryan View Post
    Yes. I got given one of these bench drill presses last year. The belt was completely cactus, not surprising as the drill had been sitting unused for close to 30 years.
    I've got a length of link belt that I'll use to get it going again when I get around to it. Got to get a new switch as well.
    I think very little of the belt tensioning system - pinch bar or timber wedge adjustment. If I had a spare 240V 3 phase motor I'd stick it on with a VFD. Only motor I have that'd work is a 415V one and without disassembly it can't be altered - I already looked at the connections. Too much hassle to bother. I could use it as-is with a 415V VFD but the cost of the plug, wall socket and VFD exceeds the value of the drill press utility to me.
    PDW
  15. #15
    Nov 2011
    Port Sephens NSW Southside
    123
    First used this Stirling drill as a second yr apprentice in '76. I later acquired it in mid '93 when the workshop was closed. It has a single phase 1/3 hp Crompton Parkinson motor (might look at fitting a 1/2 motor I have). Jacobs No34 chuck / JT6 taper. Fixed chuck runout last year as someone had scored the taper.
