Results 61 to 75 of 529
Thread: Show us your Shaper
5th Mar 2012, 11:42 PM #61Novice
- Oct 2010
- Fife Scotland
- 24
Welcome laddie
Hi Ray,
It sounds good in any language...thanks.
Does your support group also cater for all our "sheila's"...and what they have to put up with constantly?
I remember my wife coming out with a "brew" for me and my mate one day, when we were wrestling with the later 14M...trying to get it off the trailer and man-handled into the shed...sweat lashing off us everywhere...(it was our one warm day that year!)...
She took one look at us...trying to shoe-horn, yet another big oily lump into the shed...shook her head...and walked away mumbling something about...
"I wish he had taken up knitting or sommat"!
Anyway...we all have our cross to bear...mine is, that I am a "shaper-nut"!
By the way Ray...I like your Varnamo Shaper...very nice!
The "swedes" make damn fine machine tools...
Back when I was still in the Toolroom (before I retired)...we had a Thule 24 inch Shaper (made in Malmo, Sweden)...That was a "beast"!
You just couldn't stop this thing!
Both myself, and the other Toolmaker...used to try and see if we could "stop it" (we were much younger, and daft back then!)...
However, neither one of us could wind enough feed on...on the backstroke...to get it to "flinch" while making a cut...
It was just bigger and bigger "bullits"...pinging off the job, bouncing off the wall...and then falling, sizzling onto the floor...
Ohhhh...Happy days!
Regards,
Neebs
6th Mar 2012, 12:03 AM #62Most Valued Member
The only one I have seen in good condition here (with the electric head movement) started in auction at $6500 I dont know if it sold.
I don't have the tooling or a work piece large enough to push my shaper. 5/16 is the largest I have . But then for what I use it for thats enough.
6th Mar 2012, 12:47 AM #63Novice
- Oct 2010
- Fife Scotland
- 24
Power is relative
Hi Stuart,
I wasn't advocating that we abuse (push) our Shapers, not by any manner of means...
However, to clarify matters...it must be said that, in my opinion:
...size for size, the humble shaper is probably the most powerful single machine you are likely to own.
It's sole purpose in life is to push that tool forward...irrespective of what is in the way!
It follows then, that the larger machines are extremely powerful for their size...and if I recall, the motor on the Thule 24 inch Shaper was around 10hp...
That is a serious amount of "grunt" to have at your disposal...and to be quite frank, to be able to watch one of the bigger Shapers "hog off" metal, when required...is a jaw-dropping experience!...if you can dodge the "bullits" pinging off the tool-tip!
Like I said...as you get "hooked"...you need a bigger "fix"!
Regards,
Neebs...the Shaperholic
6th Mar 2012, 01:15 AM #64Most Valued Member
6th Mar 2012, 06:46 AM #65Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Neebs,
I have been trying real hard to not reply in accordance with the guidelines set out in Shaper Therapy but I can resist no longer. Outstanding collection of shapers!
I weakened on the weekend (and I was doing so well), I needed a small bit of steel to hold some drawings flat on the bench. Now normally you would just pick up a piece and place it in the appropriate position on the paper. Not me. I took this small piece of 25mm square black bar over to the shaper and cut a male dovetail in it. Now it looks like an engineered paperweight. I kid you not!! I am so proud of it that it now lives inside the house on the office desk. It seemed silly making it for just one bit of paper. As you can see and as RayG pointed out there is a serious problem (although I am yet to be convinced) and help should be made available.
Some people collect stamps but where is the fun in that.
More pics please, more pics, I need them now
Phil
6th Mar 2012, 10:17 AM #66Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Non Slip Dovetail
Phil
I can see a benefit in that paper weight, because the dovetail allows a good grip.
It appears to be an accurate 60 degree,
Well done
regards
from the Shaper support group Dural NSW
Bruce
6th Mar 2012, 10:27 AM #67Most Valued Member
- 4,255
6th Mar 2012, 10:58 AM #68Novice
- Oct 2010
- Fife Scotland
- 24
Dovetail paperweights et al
Hi Phil,
Glad you like my Shapers...thanks for that!
Phil...A very nice dovetail...but of course, as a "Shaper-Nut", I would expect absolutely nothing less...when producing dovetails on a Shaper...no fuss, no drama, no broken tools, no bad language...just a beautifully made component time and time again...
...and all done with a little bit of HSS that only cost a couple of quid!
Unlike those poor souls...with only a milling machine to produce dovetails...
£50 for the dovetail milling cutter, another £50 for the Vallium you need to take before you switch the Mill on...and then another £50 for the paper hankies...for all the tears when your Dovetail milling cutter snapped with no warning!...bummer!
You Milling "chappies"...have a nice day now!
Think I'll stick to my Shapers!...for the "tricky" jobs!
I have attached a couple of photos of a set of "dovetail paperweights"...I made for a mate of mine...just a month or two back...
Oh sorry...It was actually supposed to be a QCTP with eight toolholders...18 dovetails in total...all done on the shaper...
However, as he hasn't got around to fitting it to his Emco Maximat Lathe yet... technically...they are still paperweights!...and in one of the pics you can see how many dovetails were needed to hold the paper down!
Regards,
NeebsLast edited by Neebs; 6th Mar 2012 at 12:36 PM. Reason: oops spelling error
6th Mar 2012, 12:08 PM #69.
- 6,458
Hello Neebs,
Any chance of some close up shots of the method of dial indicator attachment?
I imagine the Elliot has graduated collars on the horizontal and vertical table feed screws. Those of us down here who own little Douglas's don't and in my case, cutting a dovetail on the mill is easier.
BT
6th Mar 2012, 12:59 PM #70Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
6th Mar 2012, 01:21 PM #71Dave J Guest
Thats what I was thinking, even tack welding them together, then machining the sides with the tacks off last to clean them off. I don't think I would have the patient to do them all one by one.
Still a nice job you did on those for you mate. He would have to be happy with them.
Dave
6th Mar 2012, 01:43 PM #72Dave J Guest
Hi Phil,
Looks good, is that your first dovetail? If it is, it looks like you did well.
I had to think what shaper you had, then when I looked I remembered your comment and mod about the table support and it flexing. I think that is because you have the short base model, because I haven't heard anyone else complaining and I don't find I get any flex to really talk about. I am not sure when or why they brought out the short base, but I don't think it was a good decision. I am wondering if these where the first type of bases, is yours a plain bearing model?
You shaper came up well, I was looking on you tube the other day to find out where a washer went and spotted yours running. I wasn't able to spot where the washer went on any of them, but thankfully Jordan and Pipeclay helped me out of where the brake washer and spacer washer went on the clutch shaft.I pulled it down before Christmas and had forgotten where they went. I did take pictures of the assembly before I dismantled it, but my memory card disappeared on new years along with a lot of other pictures, after putting it away safe in my wallet.
My Douglas is down getting mods, it only started out with a clean after mounting a grinder to it to do some surface grinding, then I thought I would paint it, now I an doing some major modifications to it. I will do a thread on it when I am finished, I just want to test it all out first, so then others could copy it easily.
Dave
6th Mar 2012, 04:02 PM #73Most Valued Member
- Australia east coast
- 2,713
Au contraire, I don't weep, I build a tool for the job.....
Cutter pictured is a Cat 40 taper shank machined by myself, 5 teeth made of HSS stick-welded in position using E4111 rods (with a hell of a lot of pre-heat) and ground on a T&C grinder. Note that I didn't go overboard WRT the finish of anything that isn't a cutting edge. Cost, peanuts. Robustness, high. Speed of cut, considerably higher than on a shaper. Length of cut, *much* greater than on most shapers. Who has a shaper with over 30" of travel? Some, but not many, I'll bet.
Horses for courses.
That's a Swedish Prema 20" shaper that the cutter is resting on so it's not like I'm not a member of the club, just that it's not necessarily the best tool for every job.
PDW
6th Mar 2012, 11:12 PM #74Novice
- Oct 2010
- Fife Scotland
- 24
I will try and answer your queries/comments in order...
Anorak Bob: Yes the Elliott's have graduated dials (very handy!)...see pics.
...Nothing fancy with the DTI attachment...I usually just use either a Magnetic Stand or my Baty Clamp...see pics attached...so, as yet, never needed to make a dedicated holder for the DTI for use on the Shapers...
Having said that...you have quite a bit o' room...on the mid range machines to clamp/put "stuff"...luxury!
Note: I tend to "use" the DTI's as a "zero" datum...as my memory isn't as good as it was...and as a result... it is too easy to "loose the plot (or position)"...when "distracted" (and with five grand-kids...you get distracted...a lot!)
At least if I have set a "zero datum"...I have somewhere to go back to!...when they have all dissapeared.
Nadroj and Dave J: Glad you like the QCTP...I could have "stacked" them...but I didn't...
There were very quick to do individually...(to my zero datum)...so, for me, that was the easier and quicker way to to it...(no patience required)
We all have "differing" ways of working...what is fast and easy for me...may well be slow and difficult for you...Which is why, when machining...yes I accept that there is often no "right" way!...it all depends on the individual and the equipment at his disposal.
As PDW said in another post "horses for courses".
PDW: Impressive "dovetail cutter"...serious bit o' kit!...respect dude! ...and I like your Shaper!
Regards,
NeebsLast edited by Neebs; 6th Mar 2012 at 11:14 PM. Reason: I forgot summat!
6th Mar 2012, 11:20 PM #75.
- 6,458
Thank you Neebs.
Something that facilitates finding the starting point with an element of accuracy is a good thing.
Bob.
shaper
By jonroe in forum METALWORK GENERALReplies: 3Last Post: 27th Sep 2011, 12:02 AM -
Shaper
By Anorak Bob in forum METALWORK GENERALReplies: 43Last Post: 19th Mar 2011, 10:18 PM -
TOS shaper
By Bryan in forum METALWORK GENERALReplies: 91Last Post: 16th Mar 2011, 05:58 PM -
or VIC: Shaper
By Bryan in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 11th Dec 2010, 08:06 PM -
Shaper vid
By .RC. in forum METALWORK GENERALReplies: 6Last Post: 1st Oct 2008, 11:03 PM
