Results 1 to 11 of 11
Thread: tool holder id
1st Dec 2011, 09:42 PM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
tool holder id
hi i have a new tool holder.
the code is r166n-2525m-310
its a sandivik.
can someone please tell me what sort of inserts does it take.
it has a clamp. . i found the chart i was looking at confusing
i also searched there web sit with no luck.
thanks
aaron
1st Dec 2011, 10:03 PM #2Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
I got 1 result from google - a spanish site. Not the best start. What chart were you looking at? If it's on line can you link to it?
1st Dec 2011, 10:03 PM #3Most Valued Member
- 4,890
Does the tool have a shim,can you tell by looking what shape the tip may be.
1st Dec 2011, 10:22 PM #4
Hi Aaron,
Does it look like this one?
Sandvik Coromant BT25 R166N 2532 310 | eBay
1st Dec 2011, 10:35 PM #5Most Valued Member
- Oct 2010
- 1,910
hi bryan and pipeclay its a triangle shaped turning tool no shim but a small lip on the Lh side.
as well as the triangle shape its like one tip of the triangle is cut off.
bryan the chart is just my black book. infact its very similur to the tool holder pictured on page 134
its just the lip that throws me and the square end.
this all came about because i lent my fave rate tool holder.A trigon shaped one. to a mate at work and he has lost it.
do now im after a replacement one.
1st Dec 2011, 10:40 PM #6Most Valued Member
- Oct 2010
- 1,910
shore does ray.I did search you know. . thanks excerpt square end not angled. now what sort of inserts.
thanks ray
2nd Dec 2011, 05:42 AM #7Most Valued Member
- 4,890
Does the insert fit over a pin on the holder or not?
It appears it could be something in the TNMG family or possably TPMR if there is no pin.
5th Dec 2011, 06:31 PM #8Most Valued Member
- Oct 2010
- 1,910
hi pipe clay how are you. the holder has no pin ect so no hole in the insert.
i haven't had time to get the photos. ect going again.Its very similar to this tool holder. except the angle the insert is different IT has the same shape clamp as well as the little lip..
8th Dec 2011, 10:19 AM #9Golden Member
- Apr 2008
- Canberra
- 805
"I got 1 result from google - a spanish site"
I speak spanish - stick up the link and i'll see if I can make sense of it.
8th Dec 2011, 02:04 PM #10Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
8th Dec 2011, 03:25 PM #11Golden Member
- Apr 2008
- Canberra
- 805
OK, the page is called "cutting tools" and the text in blue says...
Lists withdrawn beacause of continual variation in prices. Call 011 4750-3345 or email [email protected]
Then the page has the differenct inserts listed by brand.
Azzrock - It looks like they offer an insert for your tool holder. The brand is "Porta Insertos" which are a Mexican company, however the page in the link is Argentinian. If you want me to write an email for you in spanish in order to get more info and a price, let me know.
The 'continual variation' they refer to may or may not be due to the rampant inflation that is occurring in Argentina once again. It may be easier to get a price from the Mexicans direct, as at least that way you'll know it wont change much. Also there has to be companies in America that offer the Porta Insertos brand, so perhaps some googling along those lines may help you find what you need.
Brendan
hss tool holder
By tanii51 in forum METALWORK GENERALReplies: 3Last Post: 11th Nov 2009, 08:31 AM -
Carbide tool holder.
By Woodlee in forum METALWORK GENERALReplies: 4Last Post: 11th May 2009, 10:27 PM -
tool holder
By glenn k in forum THE HERCUS AREAReplies: 5Last Post: 17th Apr 2009, 03:50 PM -
Diamond tool holder
By Pete F in forum THE HERCUS AREAReplies: 22Last Post: 9th Dec 2008, 08:27 PM
