Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    Oct 2004
    Southern Highlands NSW
    1,894
    Default Strength of phosphoric acid?
    I want to buy some phosphoric acid for rust removal.
    The local hardware has small bottles of 85% concentration.
    A chemical supplier has 81%, which they say will be OK for my needs.
    Is the 4% difference anything to worry about?
    Jordan
    Jul 2010
    9,088
    Hi Jordan,
    Well the rust remover I have in the shed is 35%. So assuming more is better, you're a long way in front of that.
    Feb 2005
    Sydney
    74
    0
    Default no noticable difference
    4% will not be noticed for what you want to do
    Gfreg
    Nov 2008
    Perth WA
    6,458
    Default Maybe an alternative.
    Hello Jordan,
    When I acquired my little No. O mill it was in a fairly appalling condition as a result of exposure to water based coolant and general mistreatment. The non painted surfaces were all discoloured with rust, some of it quite heavy. My brother in law, a farmer, had encountered Corro Dip at some country show and swore by it. As a result of immersion of those parts in Corro Dip, I do too.
    index.html
    BT
    Oct 2004
    1,894
    Thanks for the advice folks.
    Bob - the CorroDip looks like a quality product, and likely has phosphoric acid in it at a guess. I have some steel that I want to clean up before painting, and will give the 81% stuff a go.
    Jordan
    Nov 2008
    Perth WA
    6,458
    Whatever you use Jordan, don't spill the stuff on concrete and leave it. I have a depression the size of a cereal dowl in the shed floor where some Corro Dip bled out over a few days from a useless plastic milk bottle..
    BT
    Oct 2007
    Sydney
    3,112
    Hi Jordan,
    Yes mine is pretty much the same. I was using it earlier (3M "rust dissolver") and so checked the concentration. It was 30%.
    Pete
    Nov 2007
    melbourne australia
    3,228
    Jordan,
    I'm not a chemist, but with acid I would not assume stronger is better. If you are going to use it for rust conversion I would dilute it to 30-35% if that's what concentration the commercial rust converting products use.
    Lower concentrations will be safer for you and anything you happen to spill the stuff on.
    BTW what purpose is the 85% phosphoric product sold for?
    Good luck with the project.
    Nov 2005
    Darkest NSW
    42
    I've found the 30-35% "Rust Dissolver" to be fine for most purposes, especially when applied with fine steel wool.
    Just keep it away from any aluminium parts; it will remove anodising colour as well !
    Jul 2010
    9,088
    What would you thin it down with?
    Water just sounds wrong.
    7,183
    Water is the go for dilution, plus a couple of drops of wetting agent per litre - dishwashing liquid is fine.
    Nov 2005
    Darkest NSW
    42
    The wetting agent is a good idea, as the stuff doesn't wet a surface very evenly without.
    I use this stuff on machinery surfaces all the time - stinks a bit, but very effective indeed.
    7,183
    If it too concentrated it will not dry properly and sits on the surface absorbing water and forms a horrible gooey messy. To speed up the drying I bake the derusted objects in a BBQ oven on low for an hour and it goes a sort of grey-white colour which can be readily painted over.
    Oct 2004
    1,894
    Sorry, I didn't think to read the label, just saw it was 85%.
    It was in a Home Hardware shop in Mittagong NSW.
    A few good additional pieces of advice - thanks again fellas.
    I bought 35kg for just under $80.
    Jordan
  15. #15
    7,183
    Quote Originally Posted by nadroj View Post
    Wow - that is a lota rust!
  1. Acid bath strength
    By JillB in forum METALWORK GENERAL
    Last Post: 12th May 2008, 11:58 AM
