Results 1 to 9 of 9
Thread: douglas shaper gib adjustment
19th Nov 2011, 01:51 PM #1Golden Member
- Nov 2005
- adelaide
- 597
cant find a manual on douglas shaper only part manual
can anyone tell me the best procedure to adjust gib on douglas shaper please
john
19th Nov 2011, 05:11 PM #2Most Valued Member
- 4,890
Set it to a .001 gap and go from there,what part of the shaper are you setting?
19th Nov 2011, 07:00 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
What I do with any gib that has many adjusting screws, is first to back off all of them.
Then, screw one in until it's just too tight, and back off until it has just enough clearance to slide easily. Repeat for the others, one at a time.
Jordan
19th Nov 2011, 07:13 PM #4Most Valued Member
- 4,890
Which one do you start with.
19th Nov 2011, 10:18 PM #5Mechanical Butcher
- Oct 2004
- 1,898
One near the middle.
20th Nov 2011, 09:08 AM #6Golden Member
- Nov 2005
- adelaide
- 597
starting with the ram gib
i take it you slacken of the lock bolts and gib screws and retighten till there .001" between ram slide and gib
tighten lock bolts up and gib locks
there seems to be some reaction between lock down bolts in the adjustment have i loosened them too much while making gib screw adjustments
john
20th Nov 2011, 09:20 AM #7Golden Member
- Nov 2005
- adelaide
- 597
found this so pipeclays on the $$$$$ http://www.practicalmachinist.com/vb...stment-211788/
20th Nov 2011, 11:47 AM #8Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
Tanii
I found this link yesterday, it's USNavy doco on the south bend 7. Check pg 17 of the PDF. Hope it's useful.
JohnQ
the link
http://www.lathetalk.com/library/sbarmy7shaper.pdf
JohnQ
20th Nov 2011, 01:11 PM #9Golden Member
- Nov 2005
- adelaide
- 597
johnq can you repost the link fo r us thank i cant get it to work
john
Douglas Shaper Eccentric Pin Question
By Rodd Perrin in forum METALWORK GENERALReplies: 21Last Post: 17th Oct 2011, 08:45 PM -
Douglas Shaper Modifications
By Anorak Bob in forum METALWORK GENERALReplies: 39Last Post: 13th Apr 2011, 02:53 PM -
Douglas Shaper 10.5"
By jones in forum METALWORK GENERALReplies: 2Last Post: 25th Nov 2010, 07:22 AM
