Page 1 of 2 12 LastLast
Results 1 to 15 of 27
    May 2002
    in the outer reaches of Sth Oz
    75
    525
    Default brazing/silver solder help
    I need to do some brazing with silver solder and small brass rods.
    I don't want to go with oxy acetalene again too expensive on rental for the amount of time it would be used. I have been looking at the Maap burners and if they get hot enough. Anybody here use one that could give some suggestions?
    Pete
    Boycott Shampoo!!
    Demand Real Poo!
    May 2010
    Lower Lakes SA
    58
    2,607
    I think you will find a propane (LPG) torch will be sufficiently hot, and very cheap to run. Get it refilled at a servo/hardware for a couple of bucks. Or buy a torch & hose to fit to your existing BBQ bottle.
    Dave J Guest
    It will depend on the silver content, but you should be right with mapp gas. I remember seeing a turbo one or something that went up to ? 3000 + degrees, not sure exactly. I have silver solder here that I could heat all day with propane and it will only glow red and not melt.
    Dave
    Oct 2006
    Armidale NSW
    52
    915
    I have an LPG and a MAPP torch, and find I go for the MAPP especially when silver soldering. Just seems to work better.
    How thick are the rods?
    Cheers.
    Vernon.
    Jul 2008
    near Warragul, Victoria
    3,726
    Default Lpg
    Dave
    Yes same here . The propane isn't effective for brazing, not enough heat , but it is ideal for soldering and heating up rusty bolts to loosen them - that's what I use it for mostly. Plus it is only a few bucks to refill the bottle and a 2kg bottle lasts for years . I don't know about MAPP , will do a search . Mike
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi Pete,
    Good question, I'd like to know what flux and what % silver people find best.
    Apr 2009
    Horsham
    92
    Not sure if this would help but at a local industrial supply store I saw a small disposable oxy set, it looked similar to this one
    Welding equipment and supplies (TIG, Plasma, MIG, Arc, Spot, Stick) - Weld-Mart Australia
    I'm not sure if it was the same brand or not, (I can find out if you like), but the whole setup was around $150 from memory. That was the 2 bottles and the torch. No rental to pay and seemed to have a fair range of heat as they lit it up in the shop to demonstrate.
    Regards,
    Jayson
    Sep 2007
    Country West Oz
    77
    169
    I got rid of my oxy/acetelene couple of years ago and got this.
    It is excellent but only good for small jobs, the oxy bottle lasts better than I thought it would.
    Worth a look, it is cheap enough and no bottle rental.
    https://www.alltools.com.au/shop/index.php/121/4021_Bernzomatic_OX2550KC_Brazing_Cutting_&_Welding_Kit_I
    Bradford
    Apr 2009
    Horsham
    92
    Thats the one I was thinking of...
    Oct 2006
    Armidale NSW
    52
    915
    I have been using 15% silver solder and a white paste flux (borax based possibly??) that I got from a plumbing store.
    I've used it for a heap of plumbing jobs, as well general silver soldering applications.
    Cheers.
    Vernon.
    Jan 2011
    Far West Wimmera
    63
    4,049
    I just buy silver solder from a plumbing supplier. Don't know what siver % it is. I bought a largish pack. 25 rods or so for house reno use. Suitable for plumbing I hope LOL. Same as Vernon I think. Flux as well.
    Just for interest I use an OXY / LPG set. Does most things but not welding with steel rods. Saves me the cost of rental on an acetylene cylinder. I have thought about buying a kit like https://www.alltools.com.au/shop/ind...&_Welding_Kit_
    as then I could have a cylinder of gas for mig welder which gets far more use than the oxy set. Depends on cost of use tho. Oxy lasts for years.
    I am also looking into backyard smelting etc including a forge for heating using waste oil which I have hundreds of litres saved up from oil changes etc. This would enable me to heat silver steel etc for heat treatment and the like without the oxy set. Cost me a lot of money tho for the oxy set. Not so easy to get on sale. I have never seen them advertised let alone on sale. Decisions decisions.
    Nov 2007
    melbourne australia
    3,228
    I've had a CIG oxy-LPG set for 30 years. I would love acetylene, but agree the cost of rental & refill is extortionate. My only complaint with it is that the flame will often snuff out just as the workpiece reaches the correct temp for brazing. It's as if the torch's tip gets too hot and the flame goes out with a loud screeching noise. It mainly happens when I'm brazing an internal corner. I'm sure it's something to do with gas pressure or my crappy technique. Anyway, back on topic!
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Incidentally, don't use plumber's solder for solver soldering tool tips or carbide tips. For that you need a completely different alloy - I think around 65% silver. Someone help me out here...
    Jan 2011
    Far West Wimmera
    63
    4,049
    Yes, somebody help him out here. Thanks for pointing that out. I have seen massive amounts of silver soldering used to attach all sorts of tips. Even carbide tips 15 inches long attached to the top of centreless grinder work rests and I was never aware there was a special type used. I was the user not the fixer.
    I will solder tips on at some point and will have to buy some solder to have on hand.
  15. #15
    May 2010
    Lower Lakes SA
    58
    2,607
    Part 3 of the scraping series in HSM magazine talks about silver soldering carbide scraper tips on. He recommends propane on small jobs as it doesn't get too hot. I couldn't see any mention of the grade of solder used, which is an unfortunate oversight. I guess it must be a softer one. Joe is this the application you meant, or were you thinking of turning tools?
  1. Silver Solder Pt 2 How to
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 11th Jan 2007, 10:51 AM
  2. Silver Solder Pt 1 info
    Last Post: 11th Jan 2007, 10:45 AM
