Results 31 to 36 of 36
Thread: Light Duty Metal Linisher
23rd Jun 2017, 10:25 PM #31
I know this is an old thread but I've decided to buy one of H & F's linisers while they are still on sale
probably the BS 48 model, just a question on what grades of belts do people find the most usefull
for general use on steel and the occasional brass?
Leroy
23rd Jun 2017, 11:09 PM #32Most Valued Member
It depends on how much you want to remove, I use mainly 60 and 80 grits which leave a reasonable finish, I keep the older belts for a finer finish, they're not as aggressive a cut. I also use mine for sharpening drill bits and shaping wood.
23rd Jun 2017, 11:28 PM #33
Hi Kryn,
the kind of use I'm thinking of is the rounding the ends of 10x 30mm steel bar with a 15mm radius, just an example,
wasn't sure if 40 grade would be too aggressive,
leroy
24th Jun 2017, 12:35 AM #34Most Valued Member
60 or 80 will do the job very nicely, 40 grit is REAL rip it off stuff, I don't think I've ever gone that coarse. For Brass I presume you want to polish it? In which case I'd go for the Scotchbrite belts, all this can be gotten from The Sandpaper Man, he's in Qld and is a sponsor on the Woodwork Forums, you'll find them under the listing of Sponsors Forum almost to the bottom of the WWF page.
https://www.thesandpaperman.com.au/s...mages/logo.jpg email [email protected]
24th Jun 2017, 11:34 AM #35Banned
- Feb 2015
- Oz
- 73
- 459
What belt sander do you have Kryn?
24th Jun 2017, 06:39 PM #36Most Valued Member
I have the Multitool 914 X 50 mounted on an A & A 8" grinder with a wire brush on the LHS. I don't run the disc on the Multitool, too small for my liking.
Also have a 16" drum sander that I run steel through to clean off the old paint occasionally, a Woodfast 12" disc sander. and an Ozito portable belt sander.
I listed them all, coz I wasn't sure which one you were referring to.
Light duty headstock spindle fitting.
By Mark Horridge in forum THE HERCUS AREAReplies: 0Last Post: 11th Apr 2010, 11:59 PM
