Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 83
Thread: QUALOS lathe
  1. #61
    Jun 2016
    Ballarat, Vic Australia
    6
    Ok thanks for the advice, you don't think these would be any good at all?
    11pc 8mm 5 16" Mini Lathe Carbide TIP Tool SET Metal Cutting Turning Boring BIT | eBay
  2. #62
    Jul 2008
    near Warragul, Victoria
    3,726
    Default Not really
    Hi
    Those are brazed carbide tools, the carbide tip has been silver soldered to the shank , they are not suitable for your job because they dont have enough rake and they are not sharp enough .
    These are better , you need to buy the correct holder for these inserts, the insert is fixed to the holder by a screw . As the tip wears, you rotate the insert around .
    10pcs Aluminum TCGT110204 AK H01 TCGT21 51 AK H01 Carbide Inserts Case | eBay
    STGCR1212F11 12×80MM Index External Lathe Turning Holder FOR TCMT1102 Inserts | eBay
    This holder may be Ok for the inserts
  3. #63
    Jun 2016
    6
    Default Thanks
    Thanks for that, I measure the from the bottom of the toolpost to the centre and only have 2.5mm difference, I may have to remove the toolpost but that will only give me 12.5mm then, half an inch
  4. #64
    Jul 2008
    3,726
    Hi
    Can you upload a pic of your tool post? thanks
  5. #65
    Jun 2016
    6
    Default Toolpost
    Qualos Tool Post.jpgThis is virtually the same as mine, mine can clamp in all four sides and is about the same height
    Can you upload a pic of your tool post? thanks[/QUOTE]
  6. #66
    Jul 2008
    3,726
    From your description, its a 4 way tool post you have . If you feel that the 1212mm insert holders are too thick for your tool post , you can then look at smaller carbide insert holders . The carbide tips are available in a few sizes smaller than the 11 examples I linked to. TCMT 09 or 06
  7. #67
    Jul 2011
    ACT
    3
    Hi Metmachmad, I also have a Qualos lathe and have been looking for any documentation on it. Is there any chance you can send me the pdf? I am also located in the Riverina however the lathe is in storage until I build my workshop.
  8. #68
    Metmachmad is offline Turning useful pieces of steel into scrap metal.
    Jun 2010
    Riverina, NSW, Australia
    68
    138
    Quote Originally Posted by ooah View Post
    OK, I'm sorry I have missed your post. Do you still require the Qualos Operators Handbook on pdf? Or anybody else if they would like a copy.
  9. #69
    Feb 2019
    Seymour victoria
    37
    5
    Hi I just purchased a qualos wondering if I can get pdf aswell
  10. #70
    Jun 2010
    68
    138
    Quote Originally Posted by Henry qualos View Post
    Sorry I missed your post above, I have been somewhat inactive here for a while. PM me your email address and I should be able to send it. That applies to anyone wanting the Qualos 5 1/4' operators handbook on pdf file also.
  11. #71
    May 2019
    Melbourne, Australia
    44
    I just bought a Qualos from an elderly gentleman in the next suburb over... the only thing it's missing is the steadies and the change gears.
    I was also wondering if you can buy different slides for it? maybe something with a T-slot?
  12. #72
    Jul 2016
    35
    1,522
    I think with a qualos you are well into the make it yourself territory, at least you'll have a mill soon.
  13. #73
    May 2019
    44
    Quote Originally Posted by caskwarrior View Post
    Haha! very true!
  14. #74
    May 2019
    Beverly Hills,nsw,Australia, Great southern land
    1
    Default require the Qualos Operators Handbook on pdf
    Quote Originally Posted by Metmachmad View Post
    G-day Metmachmad, and everyone following this post.
    My name is David, (Qualos Junior the number on the bed shows as 09 or 60 )
    I am 48 yrs young and have been given a Qualos Junior lathe all parts were in a box the joy of a new project. I have been searching for a manual on the computer and came acros this thread I would like to ask if I could get a copy of the pdf Operators Handbook you have mentioned please.
    thanking you all in advance for any help on this.
    kind regards
    David
  15. #75
    Jun 2010
    68
    138
    Quote Originally Posted by David Saxberg View Post
    PM sent
  1. Travelling steady for a B model Qualos
    By Metmachmad in forum METALWORK GENERAL
    Last Post: 2nd Sep 2011, 11:49 PM
  2. Newbie looking for some help with Qualos
    Last Post: 11th Aug 2010, 10:32 AM
  3. SOLD: Lathe for Lathe Drill Mill (Near Liverpool NSW)
    By Auskart in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 29th Jun 2010, 07:02 PM
  4. Buying a lathe (Old massive Lathe, or New small C6 Lathe)
    By Ch4iS in forum METALWORK GENERAL
    Last Post: 25th Mar 2009, 12:19 PM
