Results 16 to 30 of 83
Thread: QUALOS lathe
22nd Sep 2013, 09:25 PM #16
Qualos
Soldiers training on QUALOS lathes at Melbourne Tech. during WW2
Mike
24th Sep 2013, 08:31 AM #17Senior Member
- Newstead Victoria
- 459
23rd Oct 2013, 05:22 PM #18Intermediate Member
- Sep 2013
- 30
Soldiers training on Qualos lathes
Hi Mike,
Thanks for the photos posted last month. Must admit I hadn't looked at forum for a few weeks.
I'd say the ones on the right are the Qualos Juniors. Small world department: my neighbor 3 doors up has one of them!
Have been tidying mine up and just waiting for rain to stop to finish painting the legs. Once that's done I will re-erect it. They are the only things I intend to paint as there was a bit of rust on them. I have painted the underside of the chip tray for the same reason, the lathe itself is being kept in its "working attire". It's looking pretty good just cleaned up. Sourcing a new Aluminum tailstock hand-wheel with a handle that looks a bit more like the original instead of the "pulley" that was used on it as a hand-wheel. Will still keep a lookout at Bendigo Swap next month just the same for an original.
Jacques
23rd Oct 2013, 06:47 PM #19Novice
- Oct 2012
- Bittern, Australia
- 13
gear setting
Hi Jacqualos,
A method I have used for years to set the mesh of the change gears is to insert a piece of paper between the gears when pushing them into mesh. After the stud is tight roll the spindle by hand till the paper is ejected and voila - clearance.
Enjoy you lathe, Borriss
25th Oct 2013, 07:33 AM #20Intermediate Member
- Sep 2013
- 30
Checking change gear clearance
Hi Boriss,
Thanks for that handy hint on setting the clearance on the change gears using a piece of paper.
Sounds good to me!
It's a bit like some of the old auto mechanics using a matchbook flap to set the points on a car. Worked well for thousands of cars too. Sometimes the simplest is the best.
Jacques
25th Oct 2013, 09:26 AM #21Turning useful pieces of steel into scrap metal.
- Jun 2010
- Riverina, NSW, Australia
- 68
- 138
I have the same model Qualos as your lathe Jacqualos. Can you tell me how many and numbers of teeth on the change gears you have?
Also, did your lathe have its travelling steady with it?
I have found that chainsaw bar oil is also more than adequate for oiling the beds ways and all the oiling points around the lathe.Turning useful pieces of steel into scrap metal.
25th Oct 2013, 05:34 PM #22Intermediate Member
- Sep 2013
- 30
Qualos lathe- change gears- teeth, numbers of
Good Day,
I have the complete set which consists of 5 gears: 20, 40, 50, 80, 100 teeth.
Have included a photo of the two point traveling steady on the saddle- took "artistic license" and did not bolt it down for photo. Still haven't looked through all the stuff in the box of bits and pieces that came with it. No doubt the bolts are there. Easy fix if they are not anyway.
I was very lucky as the lathe was very complete for something built over 60 years ago. Even have the original Operators Handbook which our friend found in her late husband's bookcase and he was the second or third owner of it. It was leveled on 12th June 1951 as written in the notes so I have some idea of its age.
Speaking of which, I had previously obtained a pdf file of the manual from Mitutoyo Qualos here in Melbourne and they have kindly given me permission to post it here if I wish. Also have some pdf file period sales brochures they also sent me.
Let me know if you are interested, and if the forum allows files these large to be posted, I will do so. I don't think they are excessively large but must investigate what is maximum allowable.
Jacques
25th Oct 2013, 07:07 PM #23
25th Oct 2013, 07:49 PM #24Member: Blue and white apron brigade
A year or so back I was visiting a local oil distributor to pick up some bulk chainsaw bar and chain oil and the distributor asked me how tacky I would like the oil because he could make it as tacky as I liked. I was very impressed at how stringy he could make the oil. When I asked him what was in the tackifier he gave me a copy of the MSDS sheet and I do not recall it containing anything common like PVA. I just did a quick check of some MSDS for Chainsaw bar oil tackifiers and they show it contains polyisobutylene and ethylene-propyline copolymers, there's no woodworkers PVA in it or VV. Maybe it was once made like that but not these days.
25th Oct 2013, 10:18 PM #25Intermediate Member
- Sep 2013
- 30
Swarth making-soon
Hi Mike,
No argument there! If Melbourne weather would dry out I would have had it up an running by now. I'm afraid the truck restorer comes out a bit with me on this project and I want it at least a bit tidy before I start. All I need is two good days to finish off painting the legs and I can re-erect it.
Is it as addictive as restoring a Ford "Blitz"? If so, I am in trouble big time!
Jacques
13th Nov 2013, 06:36 PM #26Intermediate Member
- Sep 2013
- 30
Qualos lathe on Gumtree
No doubt many people may have seen this one but Gumtree has a 5 1/4" Qualos lathe for sale at Circular head.
Still waiting for dry weather to finish painting the stands. Found when I stripped them they were full of a lot of casting flaws and looks like they were factory filled with a type of early spray putty on the visible sides anyway. Wish now I hadn't done it and just thrown another coat of paint over it but we are all wise in hindsight. So a bit of back filling and sanding is now required and the 2 day job has blown out to a quite a few days weather notwithstanding.
Anyway, sorting out the big box of bit that came with it while I wait, and making a lookfor list for Bendigo.
Have a question: Just curious does anyone recognize the trade mark on the tool holders that came with it? See attached photo. Obviously Australian made so would think they are the same vintage as the lathe.
13th Nov 2013, 07:02 PM #27Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Pretty confident they are Lock brand.
Phil
13th Nov 2013, 07:27 PM #28
another
Did you spot this Jacques ?
1940
13th Nov 2013, 07:58 PM #29Most Valued Member
- 70
- 1,514
Tool holder is a Lock. The one I have has this symbol on one side with a couple of other letters and Aust. Other side has LOCK.
Nev.
13th Nov 2013, 07:58 PM #30Intermediate Member
- Sep 2013
- 30
Qualos lathe on Ebay
Hi Mike,
No, missed that one even though I have "Qualos" in my saved searches. It has an aftermarket tailstock handwheel also as mine does now. Replaced my "agricultural" pulley of a handwheel last week. They must be a routine casualty.
Thanks also Phil, for that info re Lock Brand. Could not find a lot of info on the company on the net other than it was Lock Tools Victoria. Since my earlier post I found some smaller tool holders in the box embossed with the word "Lock" but I never made the connection. Guess they are long gone like most manufacturers in this state.
Jacques
Travelling steady for a B model Qualos
By Metmachmad in forum METALWORK GENERALReplies: 34Last Post: 2nd Sep 2011, 11:49 PM -
Newbie looking for some help with Qualos
By Metmachmad in forum METALWORK GENERALReplies: 8Last Post: 11th Aug 2010, 10:32 AM -
By Auskart in forum METALWORK - Machinery, Equipment, MARKETReplies: 9Last Post: 29th Jun 2010, 07:02 PM -
