Results 1 to 10 of 10
Thread: Diamond Tool Holders - AGAIN
23rd Sep 2011, 08:15 AM #1Most Valued Member
- 4,258
for those who are interested Eccentric Engineering now have a left handed version available.
Tool Selection and Ordering
23rd Sep 2011, 12:43 PM #2Most Valued Member
I've just ordered a right handed one in the new 12mm size. I'll let you know what I think when I've given it a run.
23rd Sep 2011, 02:59 PM #3Most Valued Member
It just arrived in the mail. Ordered late yesterday afternoon. Now that's quick!
23rd Sep 2011, 07:38 PM #4Senior Member
- Aug 2007
- 292
Thanks for the heads up. Looks like I will be spending some toy money.
Pete
25th Sep 2011, 12:38 AM #5
Got mine (right handed) about 2 years ago. It is my most used tool.
Love it.
Phil
3rd Oct 2011, 07:52 PM #6Most Valued Member
I've had a chance to test the DTH. First impressions are very good. The supplied HSS tool bit was only partially ground, so I had to finish grinding the profile on my bench grinder. Boy is that Cobalt HSS hard! The job is very simple thanks to the jig, just time consuming (I only have a 1/2HP grinder).
I have tested the DTH on MS bar and Delrin, and it's fantastic. Turning and facing can be done with the same tool setting. It peels off long curls of steel without the use of coolant and didn't show any sign of bluing or blunting. The Delrin almost has a polished finish on the face.
I'm looking forward to testing it on some more materials soon. I can see this being the first tool I put my hand on for most jobs.
3rd Oct 2011, 08:51 PM #7Most Valued Member
This is one small problem with a DTH, long curls can be a pain(for starters it wont go up the vacuum). I've found most times that if you push the cut harder it will break up, of course you dont always want to do it. One of these days if it ever worries me enough I'll try a chip breaker groove.
What sort of wheels do you have on your grinder? I grind my HSS on a little Elu(?) I don't think its even 1/2hp. Starting from a square blank I dont recall it taking to long. What size HSS do they take again?
3rd Oct 2011, 11:02 PM #8Most Valued Member
I've got 38A white oxide wheels. 46 & 80 grit. The tools are 1/4".
Is yours M42 cobalt HSS? It's considerably harder than the M2 tools I have.Chris
3rd Oct 2011, 11:37 PM #9Most Valued Member
I think that all sounds about right. Thinking about it, the Cobalt HSS I have is 5/16", but the 1/4" HSS I used for the DTH is just cheap stuff so forgot what I said about the time, sorry.
3rd Oct 2011, 11:51 PM #10Most Valued Member
No worries at all.
CheersChris
Left and Right Tool Holders
By RayG in forum METALWORK GENERALReplies: 14Last Post: 30th Nov 2010, 07:34 PM -
carbide tool holders and tips
By tanii51 in forum METALWORK GENERALReplies: 9Last Post: 29th Sep 2009, 06:01 PM -
Tool Holders
By footz in forum THE HERCUS AREAReplies: 9Last Post: 23rd Sep 2008, 10:34 PM
