Results 1 to 15 of 17
Thread: Lube points....but not sure
18th Sep 2011, 09:37 PM #1
On a few machines, I have noticed what I think are oiling points . You see a brass plug with a ball in the centre, the ball is spring loaded , something like a one way valve . You can press the ball inwards and it springs back.
I've seen these on sewing machines and the mill drill I have has them also .
Can somebody explain what they are and their function
mike
18th Sep 2011, 10:12 PM #2Senior Member
- blackburn vic
- 297
Hi Mike
They will be oiling points.
Give them a quick wipe with cloth to remove swarf, press the nozzle of an oil can against the ball and give them a squirt or two. Some oil can nozzles are better than others at getting oil in without lots on the outside.
Roger
18th Sep 2011, 10:22 PM #3
thanks
Ok Thanks Roger .
Are you the ham VK3BKR ?
Mike
18th Sep 2011, 10:25 PM #4Senior Member
- blackburn vic
- 297
Guilty yer honour.
Roger
18th Sep 2011, 11:13 PM #5
20th Sep 2011, 12:09 PM #6
20th Sep 2011, 02:48 PM #7Dave J Guest
20th Sep 2011, 03:56 PM #8
right
Yes , I did try the oil can as in the pics by Dave and it works fine ......
BTW I read somewhere that chainsaw bar oil is ideal for ways as it is somewhat sticky . One could possibly use it for other areas of machines as well
Mike
Regarding Ham radio ... A lathe is handy for making various home brew fittings so the two interests do intersect to some degree .
20th Sep 2011, 06:07 PM #9Dave J Guest
Greg had way oil available by the liter a while back, he might still have some. Also there is a place down your way selling it by the 5ltr container instead of 20ltr. Someone will jump in and let you know.
Dave
21st Sep 2011, 07:35 AM #10Senior Member
- Dec 2010
- Syd
- 492
Originally Posted by rogerbaker
21st Sep 2011, 08:25 AM #11Most Valued Member
I'm sure guys of your expertise and calibre would be able to machine up their own dedicated brass nipples for oiling the lube points......
Also, treat those lube points nicely becaue I have a couple where the ball has disappeared and now there is simply a brass hole with no ball...
BTW, has anyone done a mod to their lathe headstock that changed their splash oil lubrication system into a pressure feed system? Just thought I'd ask
21st Sep 2011, 09:12 AM #12Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
No but I can tell you how to remove your stuffed oilers. It involves a tek screw, pliers and a hammer. Is that enough info?
21st Sep 2011, 09:19 AM #13Most Valued Member
21st Sep 2011, 11:09 AM #14
Oilers
I found these are available ..MIKE
RDG Tools - Online Engineering Tools Button Oilers
21st Sep 2011, 11:32 AM #15Most Valued Member
Hey Bryan, If you get the right sized self tapper and a claw hammer you can get away without the pliers lol
I hate the things. Yeah most of them work most of the time but I still hate them. I'm slowly replacing the ones I can with oil cups. I've thought about replacing the ones were a cup wont suit with a grub screw. I've decided against that so far as I figure I'll forget to oil one.
Spindle and way lube
By kats1719 in forum THE HERCUS AREAReplies: 9Last Post: 31st Jul 2009, 05:54 PM
