Results 1 to 15 of 19
Thread: Threaded milling cutters
15th Sep 2011, 03:30 PM #1
I was reading Harold Halls book on milling and he recommends the threaded shaft type end mills over the plain shank type. He says they are more accurate and have a firmer hold in the machine .
The machine I used at at TAFE used the threaded end mills with a special collet . You screwed the cutter up into the chuck to the end of it' s travel, then you backed it down a tad before tightening the chuck around the collet.
Is it possible to use the threaded cutters in a R8 spindle ?
Any comments appreciated
Mike
15th Sep 2011, 03:47 PM #2.
- 6,459
Depends on what's on the end of the R8 arbor Mike. If it's say, a ER collet chuck, yes.
I don't know if I would agree with Harold's view on accuracy though. I have ER chucks and Autolock chucks. Some of the ER chucks and their collets may not be as accurate as the Autolock but the accuracy of the cutters used in them would come down to manufacturers and their tolerances. The majority of the cutters I use in both types of chucks are the screw shank variety made by Clarkson, Dormer, Presto, Sutton and P&N amongst others. All of them as accurate as I would ever want.
BT
15th Sep 2011, 03:53 PM #3Most Valued Member
Hi Bob,
I think Mike might be asking if you can get a Clarkson chuck on an R8 taper.
15th Sep 2011, 03:59 PM #4
Found this on EPAY
POSILOCK MILLING CHUCK R8 FOR ENDMILLS ETC BRIDGEPORT | eBay
Not sure if that system uses threaded end mills or plain ?
I didn't think the ER chuck could handle threaded cutters ?
15th Sep 2011, 04:10 PM #5Most Valued Member
Hi Mike,
From the listing "SUITABLE FOR STANDARD THREADED ENDMILLS & SLOT DRILLS".
These chucks wont hold plain shank cutters
Threaded cutters will go in a ER chuck but the thread wont be doing anything(unless you can get some threaded collets like BT has)
I use threaded cutters as a clarkson chuck came with the mill(its a little different to the posilock but does the same thing). I've just bought a set of ER32 collets, am yet to make an M12 draw bar for the mill so havent used them.
15th Sep 2011, 04:12 PM #6.
- 6,459
Mike,
It's a far eastern version of the Clarkson Autolock. I've been using screwed shank cutters in ER collets for about 6 years. ER collets don't grip the entire length of the collet so the threaded cutter end is not gripped. I will have a look for a sectional drawing to illustrate this.
BT
p.s. sluggish typing enabled Stu to beat me to the draw. "These chucks wont hold plain shank cutters" . If you are concerned about cutter slippage stick with a screw shank chuck like the Auto/ Posi Lock. Otherwise go for an ER. I have not yet had a cutter slip in my ERs.
15th Sep 2011, 04:25 PM #7Intermediate Member
- Dec 2010
- Narellan, NSW
- 48
Google "Osborn Titanic R8" - you should be able to find a used set pretty cheap.
15th Sep 2011, 06:13 PM #8
right
OK, sounds like the ER system is the most versatile being able to handle either shank version , plain or threaded. But, it would be nice to also have a screw type chuck as a backup for possibly milling the harder material like 4140 ... Mike
osborn titanic collet chuck with 4 COLLETS | eBay
PS also on EPAY ..looks rather well used though !
15th Sep 2011, 07:01 PM #9.
- 6,459
Mike,
If you feel you need a screw type chuck, a search on Ebay UK is usually the most fruitful. Search for "Clarkson", "Osborn", "Dormer", "Autolock", "Titanic".....
Clarkson made small, medium and large chucks. The collets are readily available for the small and large in both imperial and metric sizes. The medium collets tend to be thin on the ground. My search for 3/4" and 19mm medium collets started 4 years ago. Still looking.
BT
15th Sep 2011, 08:27 PM #10
Ok
OK on that Bob I guess we will just have to keep perusing ebay to see what pops up Mike
28th Sep 2011, 01:56 PM #11
collets
Just reading a book that says the OSBORN/CLARKSON collets have a 20tpi thread form irrespective of diameter. That sounds rather unorthodox. Does anyone know if the newer cutters still use that standard ? Or are they more orthodox eg UNF and Metric form.
Mike
28th Sep 2011, 02:05 PM #12Most Valued Member
Hi Mike,
All mine are they same pitch. Well ok I didn't check them all but all the ones I checked were the same pitch(thats four cifferent sizes). Most of my threaded cutters are imp though, I'll see if I can dig out a metric one.
28th Sep 2011, 02:11 PM #13
Ok
Ok thanks Stuart . This book I am reading is rather old, so it may be outdated by now. Still, it may be a trap for us who use the threaded cutters. You have 4 with the same pitch ..Hmmm it might be true then. Mike ............................ PS 20tpi = 1/4 BSW and 3/8 BSF , the other diameters are all odd ball
28th Sep 2011, 02:27 PM #14Most Valued Member
I have seven collets, all appear to be the same pitch. This is the best I can find as cutters go. 3/4, 1/2, 10mm, 3/8, 1/4
28th Sep 2011, 02:40 PM #15
Holders for milling cutters
By Tiger in forum METALWORK GENERALReplies: 4Last Post: 11th Oct 2009, 02:13 PM -
I'm after some odd milling cutters
By funkychicken in forum METALWORK GENERALReplies: 10Last Post: 4th Sep 2009, 09:28 PM
