Results 1 to 5 of 5
Thread: Power Hacksaw
4th Sep 2011, 08:15 AM #1
Power Hacksaw
Are power hacksaws supposed to cut on the forward stroke or backstroke.?
4th Sep 2011, 08:52 AM #2Intermediate Member
- Jul 2008
- TAMWORTH, AUSTRALIA.
- 78
- 30
They cut on the forward stroke, most good makes of power hacksaws lift the blade slightly on the backward stroke to save the blade.
4th Sep 2011, 10:49 AM #3Member
- Mar 2011
- Brisbane
- 56
MIne cuts on the backward stroke,
Blade lift on forward.
Work out on which stroke the blade is lifted and put the teeth so they cut going the other way.
4th Sep 2011, 12:51 PM #4Most Valued Member
Which way if forward?
My opinion is they should cut in the direction of the fixed jaw of the vice. On every power hacksaw I've seen this means the con rod is in tension. Others have reported using them "the other way" and have had no problems.
4th Sep 2011, 09:37 PM #5
Well I thought that as well , but my Parkanson cuts on the forward stroke , and I've seen a number of U tube clips where some cut on the back stroke and some on the forward .
I posted the question to a metal work forum and it was suggested to time the cut ,forward and back ward the fastest time to complete the cut is the correct direction. So that is what I did.
The lift will work in both directions of cut ,as it did on my machine.
Kev."Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
SOLD: power hacksaw
By mistercartoon in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 19th Mar 2011, 05:51 PM -
Power Hacksaw
By Bryan in forum METALWORK - Machinery, Equipment, MARKETReplies: 15Last Post: 13th Oct 2010, 07:22 PM -
Power Hacksaw Blades
By matthew_g in forum METALWORK GENERALReplies: 6Last Post: 13th Aug 2010, 01:10 PM -
Gloat - power hacksaw
By jmk89 in forum METALWORK GENERALReplies: 17Last Post: 17th May 2009, 02:49 PM -
Bandsaw or Power Hacksaw
By echnidna in forum METALWORK GENERALReplies: 9Last Post: 16th May 2009, 10:06 PM
