Results 1 to 5 of 5
    Jul 2008
    near Warragul, Victoria
    3,718
    Default DM 45 Standaco speeds
    Just wondering if you chaps who bought the yellow DM 45 are happy with its spindle speed range....... Is it 6 or 12 speed ? And if it is 6 speed: Is that good enough fpr general milling ?
    Mike
    Nov 2006
    Bendigo Victoria
    80
    7,471
    Mike, the DM45 has 6 speeds, 3 in Low and 3 in High. To my knowledge all the xx45 mills have 6 speeds.
    You can see the 6 speeds here
    http://www.woodworkforums.com/f65/ne...ml#post1268722
    I am just about to change to a 3phase motor and VFD, so it will be variable speed.
    Having said that, I haven't really experienced a limitation (yet) with those 6 speeds.
    Jul 2008
    3,718
    Default Ok
    Thanks Fred
    Its just that the ASSET version is 12 speed according to their specs: QUOTE
    spindle speeds (rpm) 75 ~ 1600 number of steps (steps) 12
    Might be a mistake on their part ..... probably is .
    SM-MD45. Mill Drill. Steelmaster Geared Head Drive Mill Drill, Dovetail Guides, Digital Depth. - Asset Plant & Machinery
    Let us know how you get on with the conversion please
    thanks MIKE
    Jul 2008
    3,718
    Nov 2006
    Bendigo Victoria
    80
    7,471
    Thanks Fred
    thanks MIKE
    I think that may be a typo as the photograph of the mill clearly shows the H/L lever and the 3 position speed lever. It also shows the same 6 speed table that all the other xx45 mills do.
    I like the Asset stuff, my lathe was supplied by the and I am very happy with that (and their service)
    The MT4 spindle would concern me a little, harder to source tooling for that from the usual suspects. The digital readout on the spindle is nice, and so is the tapping feature.
  1. Cutting speeds
    By Buncha in forum THE HERCUS AREA
    Last Post: 13th Oct 2008, 10:53 PM
