Page 9 of 180 FirstFirst ... 45678910111213141959109 ... LastLast
Results 121 to 135 of 2694
  1. #121
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi .RC,
    Amazing bit of gear, digitally selectable automatic... very slick.
  2. #122
    near Rockhampton
    6,218
    To get these back to the start do you have to run them backwards? or is there some way to get them back faster?
    This model you have to run it backwards.. Or you can turn the main lead screw with an allen key. The main lead screw has a spring loaded quick release feature in it that disengages the fine feed so you can manually rapid it..
    AFAIK the smaller UPA1, 2, 3 models have a quick return feature...
  3. #123
    Jul 2010
    9,088
    Hi RC,
    Looks like I'll need one of each then
    Thank you
  4. #124
    Mar 2008
    nowra
    1,598
    i a worried i a becoming a tool addict as i a contemplating this lot of tools.
    Andre
  5. #125
    Dave J Guest
    You can never have to many tools, your hooked, LOL
    Dave
  6. #126
    Mar 2008
    nowra
    1,598
    I am hooked
    The members here such as Bob have driven my to buy and find more accurate tools and work to higher levels or precision which i previously would not have done and i thank them for that.
    Andre
  7. #127
    near Rockhampton
    6,218
    Those Somua micrometers are nice... I have a new 25-50 one... Made in Czechoslovakia...
  8. #128
    Oct 2008
    Wimmera
    51
    369
    Default starrett
    just picked this not so little dial indicator up in as new condition and works beautifully
    the dial is quite large at about 70mm across and large number (might have been made for older machinist's )
    res .ooo1 should be usefull for the surface grinder or tool and cutter grinder
    Attachment 198361
    cheers
    Harty
  9. #129
    Jun 2007
    Vic
    48
    544
    I just bought this thing...
  10. #130
    Jul 2006
    Athelstone, SA 5076
    4,258
    took custody of this stuff today gratis from a mate...
    the edge finder and dial indicator have never been used
    the inserts are new .....the 4off at the top of the top packet are ceramic...now I need to fing a tool holder for them ...he showed me them at work on some 70HRC scrap die stuff...the tip of the insert and material peeling off was glowing fire engine red...maybe a bit brighter...and the finish..it was as though it was polished
    I asked if they worked on mild steel and as he had never tried he did a test, and the finish was nearly as good...
    as per RC tip he going to save me some old inserts so I can make some
    PS that was a solid carbide centre drill in the plastic pouch
    Last edited by eskimo; 20th Feb 2012 at 05:24 PM. Reason: forgot the photo..duh!..
  11. #131
    Dave J Guest
    Good score to all 3 of you guys, it's good when you can get stuff for free Eskimo, and it sounds like you will have a future supply..
    Dave
  12. #132
    near Rockhampton
    6,218
    My gloat...
    Jones and Shipman 540 surface grinder, managed to get it within easy driving distance.. Ex NSW Tafe, older plain bearing head model...
    The ways look to be acceptable.... Probably won't have to break out the scraper for this one. It has been bastardised a bit... They have put metric dials on the machine, probably during the metrication of Australia in the 70's.. Spindle downfeed is 2 microns per graduation, but a fine feed click moves it 2.5 microns (0.0001") same as the cross feed, one graduation is 0.04mm but the fine feed is in inches...
  13. #133
    Charlestown NSW
    65
    1,673
    R.C
    Good old machine, spent a bit of time in front of one of them. In fact I know where these is one in bits that I'm going to try and buy. Its got no motor and no coolant tank though unfortunately.
    bollie7
  14. #134
    Jul 2010
    9,088
    Hi RC,
    Nice one!
    I want one of those(but lack the space atm). Like bollie7 I've spent plenty of time in front of one of those myself.
    Whats with the cover(?) over the on and off buttons?
  15. #135
    near Rockhampton
    6,218
    Quote Originally Posted by bollie7 View Post
    R.C
    bollie7
    I would like a spare complete ball bearing wheel head for this in case the plain bearings ever give up the ghost... They are unrepairable... The finish I got when giving it a test run was quite good though, for no coolant and no balanced wheel so they could very well last me forever, but you never know...
    Hi RC,
    Nice one!
    Cover is so the controls can be physically locked out.. Maybe it was an instructors only machine at one time...
