Results 1,456 to 1,470 of 2694
Thread: todays tools gloat
10th Jun 2014, 09:26 AM #1456Most Valued Member
- 4,258
10th Jun 2014, 11:35 AM #1457
10th Jun 2014, 01:16 PM #1458Most Valued Member
- 4,258
the type i am specifically refering to are the low voltage type..usually embeded IN the windings or they can be installed later but are surface mounted to windings...both do not take high voltage....and also have their own terminals..which could be mistaken for normal motor terminals to the unwary
Then there are the type which are in series with windings but generally not applied to 3ph motors....and this type can take high voltage but do not have their own terminals....these are not thermistors as such but rather a Bi-metal switch's.
10th Jun 2014, 02:08 PM #1459
10th Jun 2014, 09:48 PM #1460
Well i just won 2 filing cabinets at our local auction house. A 3 and a 4 drawer.....filing cabinets you say? No no no, these are 900 wide units made to hold suspension files back to front. They had a drop down draw front and the drawer runs on it giving them a huge weight capacity. I already have 2 4 drawer units that cost me about $100 each. I got the 2 today for $22 and $34.
Ew
Oh, and i'm happy to put it here as it is at the expense of the Canberra public service.....1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
14th Jun 2014, 02:27 PM #1461Pink 10EE owner
- 6,218
Not had a gloat in awhile.... And this is not tool related, but is metal
2" pipe, mostly OK condition... About half of it screwed with couplings... about 180 lengths.... I paid approx $430 a tonne, about 5.8 tonnes there..
Going to use it for sheds and other stuff..
20140613_154907.jpgGold, the colour of choice for the discerning person.
14th Jun 2014, 05:16 PM #1462Banned
- Jul 2011
- Melbourne Australia
- 1,376
15th Jun 2014, 07:23 PM #1463Most Valued Member
16th Jun 2014, 07:40 PM #1464
Got my hands on a couple of new to me tools today: A 12" Moore&Wright precision square and a set of 8 small gear cutters. They are 20deg pressure angle but I haven't figured out yet what module or pitch they are yet. Anyone know how I can tell?
Also got a small single shot oil pump that I will fit either to the lathe or the surface grinder.
IMAG1279.jpgCheers, Joe
16th Jun 2014, 07:47 PM #1465Pink 10EE owner
- 6,218
Does it not say on them the size? I cannot see what is written on them in the photo other then the cutter number and the pressure angle..
No doubt somewhere there is info on how to measure them... Remembering that a gear cutters only purpose in life is to create swarf... It does not cut gear teethGold, the colour of choice for the discerning person.
16th Jun 2014, 07:56 PM #1466Most Valued Member
16th Jun 2014, 08:02 PM #1467Philomath in training
That's a curly one Joe. Start by measuring the bore. (In Australia) DP cutters have a 1" bore; module cutters are various sizes (16, 22, 27 mm diameters for starters). You then might have to cut some gears based on some assumptions about what the module/ DP is and see which ones mesh.
This also may help.
Failing that, send them across for a holiday and I'll see what I can work out...
Only 2 out of 3 for that try Simon - the number 6 is just a reference on which cutter it is in the series. Sorry.Last edited by Michael G; 16th Jun 2014 at 08:04 PM. Reason: Note for Simon
16th Jun 2014, 08:17 PM #1468Most Valued Member
16th Jun 2014, 08:23 PM #1469Philomath in training
16th Jun 2014, 08:32 PM #1470Most Valued Member
