Results 256 to 270 of 2694
Thread: todays tools gloat
11th Jun 2012, 02:25 PM #256future machinist
- Mar 2008
- nowra
- 1,598
11th Jun 2012, 02:42 PM #257Most Valued Member
Hi Phil,
Did you manage to convince the shop it was a nail cleaning kit?
Hi Phil,
Car is packed I'm on the way, not sure how cold the beer will be though. I'd been planning a trip tomorrow.
11th Jun 2012, 03:06 PM #258Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
13th Jun 2012, 06:55 PM #259Pink 10EE owner
- 6,218
13th Jun 2012, 08:25 PM #260Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Triangular Scrapers
Andre
I was using mine again today.
Great for taking off a burr. or putting a radius on the end of a drilled or bored hole.
The most important thing is to slow the lathe way down, say 60 to 120 rpm otherwise chatter will develop & you will not get the required result.
regards
Bruce
13th Jun 2012, 09:07 PM #261Most Valued Member
- Sep 2011
- Ballarat
- 3,103
14th Jun 2012, 05:29 PM #262Most Valued Member
- 4,258
she's home...anyone know where I can find a manual for the Repco Power SBO model surface grinder?
for you R8 guys....during my google search for a SBO manual I came across this
Wohlhaupter UPA/3 Boring-Facing Head Set R8 Shank
seems a fair priceLast edited by eskimo; 15th Jun 2012 at 10:12 AM. Reason: added content
16th Jun 2012, 12:14 PM #263future machinist
- Mar 2008
- nowra
- 1,598
I just picked up there brand new mitutoyo micrometers 0 -75 mm for $105 and a Moore & Wright depth Mic for $25 gotta love Ebay
Andre
16th Jun 2012, 04:16 PM #264Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
sweet
nice pickup. i had a shocker today. i lost 50 bucks and bought a few things that i forgot wouldn't work for me.
there was a new guy at the market that has all the kick atse gear. like mick set yop quality milling gear in t8 nt30 and nt 40".
tons of turning tools and lots.
19th Jun 2012, 12:47 AM #265
Hi,
I picked up this nice little dial for $20. It is a back plunger style with a nice long bore finger. Its .200" x .001" 1 1/2" face. No maker to be seen.
19th Jun 2012, 01:17 AM #266Most Valued Member
- Oct 2010
- 1,910
from memery.
hi every one. Here i go shooting my mouth off again. These triangle scrapers in the pics and posts. i think. just from memory that they are called. 3 square scrapers.
I all ways thought it strange that the 3 and square were used in the name.
I agree with bruce they make a great deburing tool.
As does my pick up. this french made deburer i picked up for $10. Once you get a hang of it its great. lucky because i brought 2.
aaron
Attachment 213082
Attachment 213083
Attachment 213084
20th Jun 2012, 07:22 PM #267Golden Member
- Mar 2010
- Nth Qld
- 687
Here's my latest Ebay score, $31 including postage which cost more than the indicator did. It was missing the screw to limit the travel on the other end to the tip so it was giving a few different readings when the stem was depressed and released. A new screw fixed the minor issue and it's ready to go. Also the "Eagle" has landed at home: a well used Colchester Bantam "Eagle", the headstock was filled with what looked like thick green 2 stroke oil in a misguided attempt to get the headstock to run quieter. It took 8 cans of supercheap degreaser to clean it out and has been filled with fresh hydraulic oil.
20th Jun 2012, 07:38 PM #268Most Valued Member
Hi Graziano,
I think I had a look at that indicactor but the postage put me off...... well that and the fact I really have more than I know what to do with already .
That a heavy duty looking lathe you got yourself there. whats the Dia of the leadsrcew?
Also whats the black knob on the left of the headstock for?
20th Jun 2012, 07:57 PM #269Golden Member
- Mar 2010
- Nth Qld
- 687
Hi Stu, The two levers on top and the top one on the front combine with a two speed motor to give 16 spindle speeds, the little stubby one on the left is the leadscrew forward/reverse. I can't check the leadscrew due to floor sealant fumes in the shed right now but it's fairly beefy, maybe 3/4" diameter, It's about 450mm from chuck to tailstock which isn't all that long. It needs a new cross slide screw most of all at the moment which is a left hand twin start screw, you can buy it online surprisingly.
Edit: measured the Leadscrew it's 1 1/8" diameter
24th Jun 2012, 11:24 PM #270future machinist
- Mar 2008
- nowra
- 1,598
I picked up this up for a $100 it's a Moore & Wright 50 -310mm inside mic that belonged to an old machinist who used to work at NSW railways Eveleigh.
Andre
