Results 196 to 210 of 2694
Thread: todays tools gloat
4th Jun 2012, 08:41 PM #196Dave J Guest
Hi Jon
Expensive aren't they, LOL Ray also has one the same as mine from H&F. Even though they are expensive, the quality seems to be top notch.
I only have the QA 150, I should have checked over the A model because it come with more holders, and the specs in the catalogs and on line are all over the shop, but I think it would have fitted mine.
I will post about them soon, just waiting on the grub screws from the UK and still working out what finish is going on them. I bought 1500 grub screws for $110 posted, compared to $30-$110 a box of 100 here.
I was going to buy a cold blackening kit as I don't want to heat them because they will warp, but have been thinking of taking them the the platers and have them zinc coated, but am unsure of the price and if they will do the lot for the minimum charge of around $60.
Nice score on the saw again, do you have a metal bandsaw?
Dave
4th Jun 2012, 09:00 PM #197Member
- Apr 2011
- 99
They are $100 a holder :O. I believe they're made in Taiwan, they do seem to be decent quality. I was considering making a few myself when i have time to commit to that project - You ended up just using mild steel didn't you?
They wouldn't be much good warped that's for sure - plating may be a better option then providing costs aren't too high.
Ouch, typical of this country, taken for a ride, then they wonder why people import stuff themselves. That's a decent price for 1500 of them.
Yeah I do, it's just a H&F BS-5S. Works reasonably well. Having had access to a cold saw for a while, I just find they are just so much quicker for fit up work, less prep work prior to welding, accuracy is debatable as a properly setup Horizontal bandsaw will do accurate cuts.
Jon
4th Jun 2012, 09:42 PM #198Dave J Guest
Hi,
Yeah just mild steel, I cant see me wearing them out as I will have a good range of them, so it's not like just one is going to get a flogging. For the regular tools I will use the 6 factory ones I have though.
I did leave the lip on the back where it gets pulled in a little thicker for more support since they are softer.
With the grub screws, at the Aussie prices I was starting to think was it worth making them as the grub screws where going to cost that much.
I bought a mixed lot of 1000 M3 - M6 just because he was combining a good postage rate and they are always useful, and the 500 for the tool posts with lots left over, some long and some shorter for the tall tools, but they come in 100 box so I had to buy that many, but will have plenty of M8 left over.
The 40mm long ones for the adjuster where $110 plus a box here, and it was only $23 off him and all are 14.9 grade. I don't need that grade but that seems to be what he sells.
This is the deal I got from this guy on ebay
stainless bolts items - Get great deals on nuts, washers items on eBay Stores!
All M8 x 1.25mm grub screws (black, cup point)
100 x 40mm long
100 x 10mm long
200 x 16mm long
100 x 25mm long
M3 M4 M5 M6 BLACK STRONG ALLEN GRUB SCREWS X 1000 pcs
Postage to Australia
The total was about $112 with the bank doing currency conversion though master card (which is the first time I tried the bank doing it with the paypal conversion rates going up)
Comparing to this online shop prices below, I got a steal.
https://www.bolt.com.au/allen-key-pr...1994_2015.html
Dave
4th Jun 2012, 10:04 PM #199
Hi Dave,
I have used these guys for stainless steel bolts before, they also sell grubs a decent prices https://www.stainlessstore.com.au/in...sort=1a&page=2 Not sure on the grade though think they are 304 stainless1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
4th Jun 2012, 10:28 PM #200Dave J Guest
5th Jun 2012, 04:00 PM #201Dave J Guest
Just a thought, when your making your tool holders and if your using this guy above, order the screws before starting as I have been waiting 2 weeks for them so far. He did mention DHL and I thought thats how they would come, but he only quoted 14 pounds postage when the ebay calculator said $29 pounds, so he may have sent the by normal mail instead.
Dave
5th Jun 2012, 04:39 PM #202Member
- Apr 2011
- 99
You did very well out of it.
I've delt with Bolt.com.au, and whilst their prices can be expensive they are good to deal with. They're handy when you just need a handful of a certain size and need them fairly quickly. But when buying the quantities you've just bought you'd go broke buying through them.
Yeah stuff from the U.K Via surface mail can take some time, it's no worse than USPS - which is hit and miss at the best of times.
With any luck you'll get them soon so you can complete the things.
Jon
5th Jun 2012, 04:46 PM #203Dave J Guest
I was only buying 350 to start off with and would have bought them locally until I added up the prices.
He said he would do a good deal on postage if I wanted more, and said he has sold to many Aussies. So thats the only reason I bought the 1000 lot of mixed sizes and the others only come in 100 boxes, so I just got them as they wont go astray around here.
This is another one I have seen but not as yet bought off. Prices don't seem to be too bad.
Bolts Nuts Screws Online |bolts-screws-decking screws-rivets-stainless steel-socket head cap screws- bolt high tensile stainless steel bolts mild steel and brass screws fasteners-socket head cap screws-drill bits-
Dave
Ps
That place is $9.50 postage or free over $99
5th Jun 2012, 06:07 PM #204Most Valued Member
Its going to be toasty warm in my shed tonight!
A mate just dropped this off.
5th Jun 2012, 06:54 PM #205Philomath in training
Toasty warm yes, but remember that one of the products of combustion is water vapour and you will have lots of nice cold cast iron sitting around waiting to condense it. Make sure it's either painted, oiled or covered.
MichaelLast edited by Michael G; 5th Jun 2012 at 09:03 PM. Reason: still can't spell
5th Jun 2012, 08:21 PM #206Most Valued Member
Yeah... I wish there was something I could do about that but the electirc heater just doesnt cut it. Its also another piece collected for casting.
5th Jun 2012, 08:44 PM #207Dave J Guest
I agree with Michael, and just in the past few weeks I had to get in a clean and oil both my mill and lathe up because I have had the electric heater going.
I have an out door one that stands 5-6 feet tall, my daughter bought it for me last birthday for the shed, but you do have to watch condensation with any sort of heat around cast iron.
I just have mine on my back when working on the mill or lathe, it seems to keep me warm enough on the coldest nights, but my hands still freeze.
Dave
5th Jun 2012, 09:27 PM #208Most Valued Member
- 4,890
I feel sorry for you blokes that need to work in your sheds once it gets dark.
5th Jun 2012, 09:35 PM #209Most Valued Member
It doesn't have to be dark to be cold down here.
5th Jun 2012, 09:37 PM #210Most Valued Member
- Australia east coast
- 2,713
It's not only the heat, it's the type of heat. LPG creates lots of water vapour, electric heat creates none. You're simultaneously raising the air temperature *and* adding water thereby compounding the condensation problem on cold(er) surfaces. Big problem in steel boats which is why I'm fitting a flued diesel heater to mine (and a hell of a lot of insulation to keep the moist air from the steel anyway).
Many years ago when I lived near the ocean in Sydney I always had condensation problems in winter. Funnily enough I'm even closer to the water in Ta and have none at all; bright steel welds ground back don't even get surface rust after 3 months in the shed. I don't have any heating though. This is why I have a lathe and milling machine in the back room of the house to play with on cold/wet days (nights).
I did find that a drop cloth like a canvas painter's cloth over the machines kept the worst of the moisture away.
PDW
