Results 2,161 to 2,175 of 2682
Thread: todays tools gloat
19th Apr 2018, 08:03 PM #2161
Thanks Grahame,
That TAPS SET in Metal Case - We2u is a really good price, even including GST and postage. They are around $25 a set on ebay... this deal has 7 sets....Cheers, Joe
19th Apr 2018, 08:37 PM #2162Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
19th Apr 2018, 09:51 PM #2163
Techo,
You are correct the microprint on the box indicates the taps were made in Bucuresti ( Bucarest) which I believe is in Romania.
If I recall I stated that Yato was a polish company brand, not that the taps were made in Poland.
There is definitely HSS indicated on the Box and in various other places listed around the net as per Item number 2976.
From what I can gather Yato tools are made all over Europe.They have been around for 25 years.
Did I mention the vice grips I looked at where stamped Germany?
regards
21st Apr 2018, 05:45 PM #2164future machinist
- Mar 2008
- nowra
- 1,598
Picked up this old Brobo super 12" today for a slab
I am hoping I can find a single phase motor for it now.BETTER TO HAVE TOOLS YOU DON'T NEED THAN TO NEED TOOLS YOU DON'T HAVE
Andre
21st Apr 2018, 07:50 PM #2165
From memory, the gearbox is designed to match the motor, the motor has a long shaft protrusion to accommodate the worm mounted on it plus possibly a support bearing beyond the worm, most have a two speed motor, all suggesting that it is a fairly specific purpose built motor rather than a generic one. My understanding is that Brobo saws were all 3phase as they were manufactured and marketed as heavy duty industrial units, so the chances of a motor graft would be low due to there not being a single phase option offered by the factory. You may well be better off trying to set up with a VFD or rotary converter to feed the current motor 3phase.
21st Apr 2018, 11:09 PM #2166Diamond Member
- Aug 2006
- 1,105
Brobo do have 240v single phase cold saws available.
22nd Apr 2018, 09:07 AM #2167Senior Member
- Dec 2013
- 201
Andre,
Nice find! I have one too, and use it all the time. So much nicer (and faster) to use for cutting stock for fabrication or machining than a horizontal band saw.
I stripped the lower half of mine back to bare metal and completely re-built it. I even found a supply of close to the original hammer tone green paint. I need to strip the top half now because the gearbox seal has failed.
Has anyone seen a manual for these machines on-line?
Graham.
22nd Apr 2018, 10:11 AM #2168
22nd Apr 2018, 11:19 PM #2169
23rd Apr 2018, 09:21 AM #2170Senior Member
- Dec 2013
- 201
Grahame,
Thanks, but unfortunately those manuals on the Brobo site are for newer saws. The Super 12" has different castings. I guess the internals may be similar though.
The coolant pumps on those newer models is listed on the drawings as Toyota - I suppose fuel pump. Someone told me mine was an older Holden pump. Any ideas? My pump needs a rebuild.
Graham.
23rd Apr 2018, 04:38 PM #2171
Joe,
I Received the catalogues from We2U. There was not a mention of these taps in the catalogue but inside the front page was some very encouraguring information.
Quote <Our Yato hand tools have a lifetime replacement warranty> I assume that this means all Yato handtools sold by We2u-
From what I can gather that virtually all of the Yato tools have the CE marking signifying that the products conform with the Eu directives or Eu regulations. Beside that there is a logo and underneath that "Manufactured in the Eu. I assume from that I am dealing with only European made tools.
If no one objects I could scan and post the page and 1 other which lists all the symbols for the various steels and standards found on the packaging applying to the various handtools.
We2u does not appear to be the distributor but perhaps the agent for a niche group of certain high-quality tools of which Yato is but one brand among others.
The niche could be best described as Automotive, with some metalworking tools around them
Anyway please leave your comments if you want me to scan and post the pages or maybe some would prefer to get their own catalogue.
Disclaimer -theres nothing in this for me , I have no connection with We2u and not receiving any benefit other than knowing at last there are some decent tools becoming available.
23rd Apr 2018, 05:09 PM #2172
23rd Apr 2018, 05:22 PM #2173
I found this - see line 12 if this is what you found?
Goss,if I recall correctly supplied the rebuild kit.
If it helps ?
23rd Apr 2018, 06:03 PM #2174Senior Member
- Dec 2013
- 201
Yes, that's what I'd seen. Henry (clear out) on the woodworker forum had told me it was something older, maybe Holden or Vauxhall, I can't recall.
But, following your lead I found: Goss - Mechanical Fuel Pumps With this I'm confident enough to strip the pump and contact Goss for identification.
Thanks,
Graham.
24th Apr 2018, 12:37 AM #2175Most Valued Member
- 5,942
Pretty sure that it is a Holden fuel pump. You should be able to get an overhaul kit from REPCO or practically any other parts replacement store.
