Results 2,086 to 2,100 of 2694
Thread: todays tools gloat
5th Nov 2017, 09:51 AM #2086
19th Nov 2017, 02:27 PM #2087Member
- Aug 2015
- 69
Another good day at the Bendigo swap.
Picked up a really nice Sip rotary table. Should be big enough for most jobs I can think of.
A box of grinding wheels which came with a bunch of arbours that I'm not sure what they suit, they have a short taper with a keyway. Anyone have any clues to where I can find out what they fit?
19th Nov 2017, 02:41 PM #2088Senior Member
- Castlemaine
- 244
19th Nov 2017, 02:56 PM #2089Senior Member
- Jun 2016
- 283
Sip rotary table
Bet it squashes your mill flat when you load it ... )
Roger
19th Nov 2017, 03:33 PM #2090Senior Member
- Nov 2010
- Frankston south
- 102
18th Dec 2017, 09:49 PM #2091Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Morehouse 300,000 lb (165 tonne) proving ring
This proving ring lurks in its (oak?) box in my shed, it comes to the surface occasionally when I'm moving stuff around. I bought it because it was cool and local to me in the early 2000s when the University of Queensland Civil Engineering Dept was having a clearout of unused gear. The story was that UQ bought the ring in the 70s, paid many thousands of dollars for it and never used it. It was unboxed for the first time to take photos for its sale on eBay.
The system for measuring load is interesting. There is a large scale micrometer mounted on the bottom of the ring and a vibrating reed which hangs from the top, measurements are taken when the micrometer tip stops the reed from vibrating. I'm not sure if load is read directly from the micrometer or if you refer to a table of deflections, I suspect the latter.
I'm never going to use this proving ring for its intended purpose, if someone can put it to use please PM me.
18th Dec 2017, 10:01 PM #2092
Alright, Bob,
I will bite. What does it do?
That is, apart from being shiny and attracting bowerbirds like me.
18th Dec 2017, 10:56 PM #2093Most Valued Member
Use it for a tramming ring on the mill?????
18th Dec 2017, 11:28 PM #2094Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Yes its shiny and beautifully made and very attractive. Its used to determine the quantum of heavy loads, i.e. zero the ring in its relaxed state, load the ring, measure the deflection, determine the load. Think of it as an analogue load cell.
The Morehouse company still exists and the proving rings are still made but the mechanical measuring system has been replaced with a digital system. Which, thinking about it, could probably be done to my ring.
MOREHOUSE: HOME
19th Dec 2017, 06:48 AM #2095Philomath in training
If nothing else it could probably be turned into an interesting base for a glass topped occasional table.
Using a ring like that is (or was at least) a reasonably common engineering practice as rings are easy to produce accurately and their behavior over small deflections is known pretty darn well.
19th Dec 2017, 10:13 AM #2096
19th Dec 2017, 02:38 PM #2097
19th Dec 2017, 09:23 PM #2098Golden Member
- Mar 2012
- Western NSW
- 543
Hi Bob
I might have a use for it and have sent you a PM.
Mark
23rd Dec 2017, 01:38 PM #2099Most Valued Member
- Jul 2016
- 35
- 1,522
Here are some extra photos of that die filer, i went back and purchased some other items from the previous owner Also, a Japanese NEWS dividing head and a tiny deckel rotary chuck, i think originally off a pantograph20171213_134754.jpg20171213_134739.jpg20171213_134728.jpg20171222_203713.jpg20171222_203647.jpg20171222_203656.jpg
Apologies for none of those being the right way up but i can't fix them on the phone.
23rd Dec 2017, 03:04 PM #2100Senior Member
- Castlemaine
- 244
Nice score. The FD rotary table is off a pantograph. Stefan Gotteswinter made a set of outside jaws for his one. Great use of a pantograph.
https://m.youtube.com/watch?v=sveMC39lpUE
What size is you News dividing head? I picked up a NEWS BS O size which has a Brown and Sharp tapper in the nose. A guy on PM had made an ER32 collet chuck with the B&S tapper so I got one of those.
Mine came with a manual if you would like a copy.
Piers
