Results 181 to 195 of 2694
Thread: todays tools gloat
1st Jun 2012, 09:58 PM #181Most Valued Member
I think all the helmets are gone. He is getting back to me tomorrow
2nd Jun 2012, 06:56 PM #182Member: Blue and white apron brigade
- 7,188
The 24V globe was shot and I ended up adapting the light surround to take a nightlight style 240V 15W globe so I am using the sign as a pilot light to remind me the compressor is on.
The compressor is located outside the shed in a sound reduction enclosure on an independent 15A circuit so I switch it on inside the shed using the circuit breaker. What usually happens is I forget to turn the compressor off and it runs on/off until I notice it firing. I cannot hear the compressor from the house when it re-charges so I do not know it still on so sometimes it stays on for weeks on end and makes a lot of water.
Anyway I added a GPO on the same breaker as the compressor but right next to the breaker box and just plugged the sign into it. Then when I leave the shed - especially at night the sign will stand out pretty clearly and remind me to turn it off
The sign comes from an analytical instrument called an X-ray fluorescence spectrometer. It was purchased in 1966 and decommissioned about 15 years ago and has say in a back room collecting dust. Last week it was scrapped and pulled apart. I managed to grab the sign and a couple of other bits and pieces. Unfortunately the sign had been dropped and I had to glue it back together again and not all the bits were there. On a personal note I used that instrument as an undergraduate in the early 70s.
3rd Jun 2012, 12:07 AM #183Golden Member
- Mar 2010
- Nth Qld
- 687
The sign looks suitably ominous, it'd give someone who broke in pause, assuming they could read. I gave the brother an engraved acrylic sign, "Experimental Darkroom No.3".....He stuck on the toilet door in his flat.
3rd Jun 2012, 10:40 AM #184Most Valued Member
- 4,258
3rd Jun 2012, 11:55 AM #185Most Valued Member
lol Where do I get one Bob?
Well I cant always be turning up gold nuggets. I paid $30 for this. Its worse the the pictures make it look. If I even get an ultrasonic clearner it the first thing going in it.
Turns out there are some more helmets available. PM me if you are interested.
3rd Jun 2012, 02:33 PM #186.
- 6,459
So Stu,
Does having the Helios put you back into the lead in the "who has the most indicators" competition?
BT
3rd Jun 2012, 02:54 PM #187Most Valued Member
Hi Bob,
Not even close. Mike(?) has me beat twice over.
It has what appears to be jeweled but they are clear? and a shutter release lifter so thats a plus.
3rd Jun 2012, 07:56 PM #188Member
- Apr 2011
- 99
Well my tool gloat today is this Soco MC-370F Cold saw that i picked up this afternoon. 370mm blade, 2 speed, 3 phase 3hp motor. Excuse the poor photo quality, my DSLR has crapped it's pants.
It needs some work to bring it up to scratch as it was left outdoors - undercover but still exposed.
Needs a new trigger switch assembly, a few bolt on pieces of the vice need replacing, and removal of the surface rust. I'm planning on stripping it completely down, cleaning and re-assembling it. Doubt i'll repaint it, too much work.
Interesting that this saw will cut parallel to the jaws, still haven't worked out the real reason for that unless you wanted to section bar stock? *shrugs*
Jon
3rd Jun 2012, 09:30 PM #189Dave J Guest
Nice score Jon, will last for years once it has had a going over.
Dave
4th Jun 2012, 05:51 PM #190Most Valued Member
- 4,258
picked up this NH Brobo Waldown
But..its missing all the spindle and pinion rack etc...and the light?
otherwise it looks almost new (but it aint as they dont make them anymore)...but why was it stripped and never out back together..
But I guess thats Tafe for you..we'll just order a new one......after all, its not our money....
now to contact Brobo and see if they have parts........ and at what cost$$$$$$?
might get turned into something else....any ideas other than an anchor
4th Jun 2012, 05:53 PM #191Most Valued Member
- 4,258
dont do this at home
heres the pics
4th Jun 2012, 05:56 PM #192Most Valued Member
I cant imagine the parts will be cheap
It would make a great(though somewhat large) dial gauge stand.
4th Jun 2012, 06:09 PM #193Dave J Guest
You should be capable of making a new quill with that big new lathe and you mill.
If you want to change it to something else, what about a tapping stand?
Dave
4th Jun 2012, 07:02 PM #1941915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
4th Jun 2012, 08:25 PM #195Member
- Apr 2011
- 99
Thanks Dave, Ueee.
Ueee - Believe it or not the vice on this one doesn't swivel, it's fixed.
Dave J - I've been meaning to ask you - when are you going to post some photo's of your toolpost holders you've been making, you know the 40 something or other of the things? I have the same style (BR/BP from Hairy Forbes).
Eskimo - Nice score, always liked the Brobo/Waldown stuff, shame it's missing the important bits.
I'd imagine the cost of the replacement bits will far out weight the cost of even being able to buy a complete new machine if you could, still it's worth a shot
Jon
