Page 138 of 180 FirstFirst ... 3888128133134135136137138139140141142143148 ... LastLast
Results 2,056 to 2,070 of 2694
  1. #2056
    Dec 2013
    Sydney
    201
    Quote Originally Posted by bob ward View Post
    ...... but basically you get a fast stroke one way and a slower stroke the other way. .......
    Are you sure you have this right? If the saw traverses in one direction from end to end, then back in the other direction between the same end points, then surely the average speed is the same in the two directions (assuming constant crank speed).
    It's the accelerations within the stroke that vary.
    Graham.
  2. #2057
    Jun 2007
    Vic
    48
    544
    Hi Graham,
    An extreme massive looking crank wheel on the diagram but that shows the forward path and return path are not the same to travel from P1 to P2
  3. #2058
    Dec 2013
    Sydney
    201
    OK, got it, thanks. The forward stroke uses less than half a crank rotation.
    Graham.
  4. #2059
    Feb 2013
    Laidley, SE Qld
    1,039
    Default Servian drill press
    $10 old style Servian branded drill press from an auction last Sunday. I know this drill press was flooded in 2011 and 2013 but the spindle and quill are free, motor is RS of course. Interestingly the column is solid, none of this namby pamby tube nonsense.
    The plan is to set it up with a permanent tapping head, but I'll need to install an intermediate pulley to get the speeds right down, has anyone done something similar?
    Bottom photo is the sellers name plate, Martin Wilson is a name I haven't thought of for many years.
  5. #2060
    Nov 2008
    Perth WA
    6,459
    Hi Bob,
    Waldown use namby pamby tubes facilitating the dropping in of an eccentric mount for their intermediate pulley - //metalworkforums.com/f65/t1818...18#post1746218
    F and R Tough like Servian used man-like solid bar necessitating a different method of mounting their pulley - //metalworkforums.com/attachmen...9&d=1503220046
    Bob.
  6. #2061
    Charlestown NSW
    65
    1,673
    Why is that Bob? If the motor was not running when flooded and it hasn't been under water for long it might be salvagable. (of course I dont know the circumstances here so I might be assuming a lot) I have a 2 HP motor that was given to me years ago that had been through a flood. It was nice and dry when I got it, new set of bearings and a new capacitor and 20 years later its still running well on a compressor.
    You might be lucky.
    peter
  7. #2062
    Jun 2007
    Ipswich QLD
    68
    1,997
    Bob you stole that drill press $10 the able on it is worth more. Pulley's I found 3 bags of them all brand new Hughie sent me up what dia you after. My modern drill press has and idler/reduction the other two stepped to give 16 speed.
    similar to this
  8. #2063
    Nov 2010
    Gippsland Victoria
    733
    Got a couple of osborne roughing cutters on ebay new old stock - great tool - far better than normal cutters that I have.
    They must be a right awkward thing to sharpen ? How is it done - google was unhelpful.
    Do ya just find some more cheap ones on ebay ?
  9. #2064
    Nov 2010
    Gippsland Victoria
    733
    Default Picture of roughing cutter
    Roughing cutters look like this. see attached photo. I got a 18mm diameter and a 10 mm diameter.
    C-tool on ebay was selling the osborne ones - they were covered in waxy plasticcy film when they arrived.
    They munch through hot rolled steel quite easily, 5x14mm cut to make T-nuts from 25mm hot rolled steel bar easily done.
    Bill
  10. #2065
    Jul 2011
    Adelaide
    837
    Default New to me Die Filer
    Just won on ebay https://www.ebay.com.au/itm/vintage-...p2047675.l2557
    I have been looking for a die filer for years and at the beginning of this week there were 3 of this exact model available. Two on ebay and one at Grays online. This looked the most original and complete to me.
    Now all I need to do is bring it back home to Woodville SA where it was made. I would love to know where the Woodfast factory was in Woodville if anybody knows.
  11. #2066
    Aug 2013
    229
    Re - Die Filer
    Good pickup, looks like it was listed in the filing cabinet category, so well spotted.
    It looks like a great machine.
    Pete
  12. #2067
    Jul 2011
    Adelaide
    837
    Quote Originally Posted by Petip View Post
    Re - Die Filer
    Pete
    Thanks, I am very pleased about the price too the one at Grays online http://www.graysonline.com/lot/0008-...etting-machine
    went for $409 plus 20% "buyers premium" and is only about 30km away from where this machine is located. However I still don't yet have a plan as to how to retrieve it and I am sure that is going to add substantially to the cost.
  13. #2068
    Feb 2015
    Oz
    73
    459
    That is very similar to my Klass pedestal drill I bought around 1985. The only repairs I've done are to make an idler pulley spigot, a bush for same and replaced the angled bush for the arms. Dam good drill, won't be parting with mine any time soon.
  14. #2069
    May 2011
    Murray Bridge S Aust.
    5,959
    [QUOTE=lamestllama;1927811 I would love to know where the Woodfast factory was in Woodville if anybody knows.[/QUOTE]
    Hi Eric, contact Graham or Steve at Woodworking Solutions Pty Ltd Address: 1174 Old Port Rd, Royal Park SA 5014 Phone: (08) 8241 2205,
    They've been involved with Woodfast for quite a few years and they might possibly know.
    They bought the Woodfast Australia business, traded for some time under that name and renamed it Woodworking Solutions. As people were buying Woodfast machines from Carbitec and others, when there was a problem, they were being expected to cover the warranty problems, when in fact it's Woodfast China's problems, as they're made there.
  15. #2070
    Jan 2016
    Wodonga Vic
    38
    633
    I rushed out at 7pm this arvo to have a look at a gumtree ad and for 180 bucks this is what came home with me (you should see the smile I'm wearing)
    Height gauge attachment for vernier calipers (first time I've come across one)
    V block on one side, vice on the other
    I'll do a close up of the individual bits and pieces soon, some of their functions are unknown to me.
