Results 1,606 to 1,620 of 2694
Thread: todays tools gloat
19th Mar 2015, 08:54 AM #1606Golden Member
- Jun 2004
- Kyabram. Vic
- 632
RC
you just want to hope that it isn't chilled cast iron. I tried some from a plough once. It was that hard I couldn't work it with carbide. 9" grinder cutting wheel did it hard and didn't last long. I was told by an old engineer that lower quality iron was used and deliberately chilled to give good wear properties.
Ken
21st Mar 2015, 03:29 AM #1607
I guess you could laay them in a nice fire and keep them orange hot for a couole of hours and then they should be 'unchilled' for machining....
Cheers, Joe
21st Mar 2015, 03:31 AM #1608
I guess you could lay them in a nice fire and keep them orange hot for a few hours and then they should be 'unchilled' for machining....
Cheers, Joe
22nd Mar 2015, 11:54 PM #1609Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Tiny reciprocating piston air pump
Not a tool, but this little device is a real cutey, its an all metal construction piston air pump presumably dating from the 50s. The brand is Hy Flo and they were made by Medcalf Bros in Hertfordshire. They were used for air supplies in aquariums and laboratories, size is 150mm x 110mm.
Medcalf Bros is long gone but there is a UK company that specialises in the Hy Flo pumps http://www.sonik-systems.com/pumps/, and there are even youtube videos on how to service them. You have to love the interweb.
23rd Mar 2015, 07:55 AM #1610
Sort of,
Not all white chilled iron is low quality ,there's some intensive engineering and metallurgy that has gone into many areas of application where white iron is used.It can only be ground,not machined and not suitable for welding repair. Some Warman pump impellors and volute liners come to mind.
Chilled iron has controlled amounts of silicon and might have been considered low quality for other applications.
23rd Mar 2015, 12:00 PM #1611Golden Member
- victoria
- 499
Test bars pickup
just a lucky day for me.
two of these test bar came my way . 14" x 52mm dia.
time to get some testing
Peter
23rd Mar 2015, 12:03 PM #1612Most Valued Member
- 4,258
24th Mar 2015, 06:29 PM #1613
RUSTY TREASURE
More scrap yard treasure 12" face plate with slight rust . The price was great - free
24th Mar 2015, 11:17 PM #1614Most Valued Member
Dropped in a molls asses bath, it should come up real nice. Good find and good price.
24th Mar 2015, 11:19 PM #1615Most Valued Member
26th Mar 2015, 12:11 AM #1616Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
27th Mar 2015, 10:44 PM #1617Most Valued Member
Evil bay win.
Managed to pick this up on eBay for the princely sum of $35.00 plus postage, it's 2 1/2" and brand new. Couldn't believe I was the only bidder
28th Mar 2015, 08:34 AM #1618Senior Member
- gold coast
- 303
Unbelievable find Kryn!!
28th Mar 2015, 07:19 PM #1619Pink 10EE owner
- 6,218
Soft as butter...
4mm depth of cut 0.1mm feed per tooth per revolution...
These borers are rigid things...
20150328_173541.jpgGold, the colour of choice for the discerning person.
29th Mar 2015, 08:53 AM #1620
Your very lucky Kryn.
