Results 1 to 10 of 10
Thread: stock size for m12
24th Aug 2011, 01:50 AM #1future machinist
- Mar 2008
- nowra
- 1,598
stock size for m12
does anyone know what diameter is needed to cut an m12 thread. also is there a free chart with die sizes i have one for tapping but not for dies.
Andre
24th Aug 2011, 02:40 AM #2
Are you talking about an internal m12 or an external m12 thread .
If your turning an external m12 thread you need 12mm stockAshore
The trouble with life is there's no background music.
24th Aug 2011, 07:48 AM #3Pink 10EE owner
- 6,218
hmmmmmm I am going to take a stab in the dark and say 12mm
24th Aug 2011, 08:32 AM #4
From wikipedia
A cylindrical blank, which is usually slightly less than the required diameter, is machined with a taper (chamfer) at the threaded end. This chamfer allows the die to ease onto the blank before it cuts a sufficient thread to pull itself along.[8]
The adjusting screws allow the die to be compressed or expanded to accommodate slight variations in size, due to material, manufacture, or die sharpness.
Russellvapourforge.com
24th Aug 2011, 09:45 AM #5future machinist
- Mar 2008
- nowra
- 1,598
okay so when you're cutting external thread the stock needs to be the same size eg m6 6 mm and m8 is 8mm.
Andre
24th Aug 2011, 09:55 AM #6Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
No, you need a bit of clearance. "A bit" will normally do, but if you want to be precise, the standard clearance for metric threads is .1082P. That is, pitch x .1082. Pitch for 12mm metric coarse is 1.75, so your clearance is 0.18935. Thats radial, so double it for diameter = 0.3787 and subtract that from nominal (12) = 11.6213mm.
I got this from the Engineers Black Book by Pat Rapp. Worth having.
Edit: The other replies are correct in that 12mm would be the best stock material size to start with, and your question did say stock.
Edit: Assuming you will turn it down to suit your needs.
24th Aug 2011, 11:26 AM #7Dave J Guest
I agree with Bryan, if you pick up any standard metric bolt and measure it, it will be under size.
The dies you buy are mostly for cleaning threads, and if you try to cut a M12 thread with a die on a piece of 12mm bar it will tear and not want to thread onto it, because it's to big.
Dave
24th Aug 2011, 11:26 AM #8vapourforge.com
24th Aug 2011, 11:37 AM #9Most Valued Member
- 4,890
If you wanted to turn the thread the max dia would be 11.966mm and min dia would be 11.701mm for a class 6g .
24th Aug 2011, 03:56 PM #10
Here's a list of metric internal and external threads dimensions.
Cheers.
Vernon.
Guide to size of electrode and bead size
By Tiger in forum WELDINGReplies: 4Last Post: 10th Jul 2009, 11:45 AM -
Tail stock centre size Help
By dude09 in forum THE HERCUS AREAReplies: 8Last Post: 19th Feb 2009, 09:01 AM
