Results 1 to 6 of 6
    Jul 2006
    Australia
    19
    Default quick change tool post help
    I'm trying to tool up some new lathes at school. We are getting four AL-1324 . I'm looking at this and this. There is a dramatic price difference. Is there any benefit in going with the more expensive type?
    Any help would be much appreciated.
    Dave J Guest
    I have the larger one and while it is a good tool post and beautifully finished, if I was to buy another one it would be a BXA wedge style for around $200 posted from the US and a heap of holders from CDCO for around $10 each. The holders are sent over in flat rate boxes and from memory you can fit 14 for in a box for $45 postage.
    So for around $550 you could have a wedge tool post and 33 holders as the tool post comes standard with 5 holders.
    Dave
    Dec 2005
    South Australia
    1,656
    Looking on the practical side buy the less expensive type it will be cheaper to replace when the students trash them and they will trash them1
    Jul 2006
    Australia
    19
    That's pretty much my thought. In my experience, high-quality items are not usually worthwhile in a school environment. Things tend to become damaged through abuse rather than actually worn out through honest use. What I really need to know, is are these two items functionally similar?
    Dave - Your point makes perfect sense, but we are not looking at setting up a vast array of tooling. Just a few toolholders per lathe will be plenty. What is the advantage of the wedge-type post?
    Dave J Guest
    The wedge type are more repeatable, but like you say the students are going to trash them so go for a piston style like this one with 5 holders.
    CDCO Machinery Corp.
    They will work out just under $150 each set and you might get 2 sets in the one box if you are after a few sets.
    The two at H&F's, the smaller one is a AXA piston style where the larger one is a Dickson style. The AXA has a piston in the middle that pushes out the tool holder onto the 2 dovetails and the Dickson style has a piston that goes into a T slot that pulls the tool holder onto 2 V's on either side of the tool post.
    Dave
    Apr 2012
    Switzerland
    1
    Quote Originally Posted by Aerohydro View Post
    @Aerohydro
    Sorry to pick up this old thread, but I am wondering how the AL-1324 went.
    I am considering buying one very soon, but am worried about Dave J's statement in another thread:
    "With the Taiwanese lathes, after seeing a AL-960B in the past few weeks and what was under the carriage etc, I was amazed it even was allowed to come out of the factory."
    Is there anything wrong with the AL-1324 you've got that's worth mentioning?
    Jerry
  1. Quick Change Tool Post
    By tinkera in forum METALWORK GENERAL
    Last Post: 22nd Sep 2010, 11:17 AM
  2. Best Way To Modify Quick Change Tool Post
    By Retromilling in forum METALWORK GENERAL
    Last Post: 30th Apr 2009, 06:10 PM
  3. QCTP-Quick Change Tool Post for 9x20 Metal Lathe
    By Big Shed in forum METALWORK GENERAL
    Last Post: 26th Sep 2008, 10:14 PM
  4. Lathe owners Quick Change Tool Post Sets
    By Penpal in forum METALWORK GENERAL
    Last Post: 17th Jun 2008, 09:02 PM
  5. Replies: 10
    Last Post: 10th Jun 2007, 10:37 AM
