Results 1 to 9 of 9
Thread: iso30 40mm arbor
20th May 2011, 11:53 PM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
iso30 40mm arbor
hi all i have looked but i cant find any where to buy an arbor for my
100 mm face cutter. the hole in the middle is 40mm
ive included some photos to male this post slightly more interesting.
Attachment 170616
Attachment 170617
21st May 2011, 12:16 AM #2Dave J Guest
How about making up a sleeve on the lathe to take a 32mm one up to 40mm?
NT FACE MILL ARBOR #F37
Dave
21st May 2011, 12:20 AM #3Dave J Guest
Here you go NT30-40mm, it was down the bottom of the page under the NT40 one's.
https://www.machineryhouse.com.au/Pr...stockCode=M545
Dave
21st May 2011, 12:23 AM #4Most Valued Member
- Oct 2010
- 1,910
hi dave how are you. if i have to i will. just thought id be able to find one
21st May 2011, 12:29 AM #5Dave J Guest
Not to bad at the moment. I just tried acupuncture last week as I am up for anything, but it's not looking good. I have only been for one visit so I will see how it goes after a few more.
That arbour from H&F's in the link above will get you out of trouble, but it is expensive.
If you contact CTC he maybe able to get you one cheaper, as a lot of members here have got things that aren't listed on his website, you just have to ask.
Dave
21st May 2011, 12:33 AM #6Most Valued Member
- Oct 2010
- 1,910
great idea dave. best of luck with you injury.
21st May 2011, 01:29 AM #7Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
DaveJ,
May I ask, what ails you?
There's nothing worse than being crook, it takes away the pleasure of escaping into the shed.
Ken
21st May 2011, 03:23 AM #8Dave J Guest
26th Jun 2011, 03:25 AM #9Most Valued Member
- Oct 2010
- 1,910
milling machines are fun
well i couldn't find one from ctc tools ect. and didnt want to buy one from hare and forbs.
so i did sleeve a a 20mm arbor was not being used. the two different size drive keys and not having any tooling to machine the slot in the sleeve made the job more complicated than it should of been.
after making the sleeve,t shaped drive key and the big washer to hold it all together.
i mounted it in the mill at work and gave it a spin.
i haven't used one of these tipped face cutters before and i really was impressed with the result. . so i took a few cuts on a extended cross slide casting that was yelling out to be finished. after that i dont think ill be bothering to do any fly cutter style facing work again.. now im trying to think of other jobs i can use it for.
how much can two 40mm axles carry?
By journeyman Mick in forum TRAILERS & OTHER FABRICATED STUFFReplies: 10Last Post: 13th Mar 2011, 10:11 PM -
Making a ISO30 holder
By Stustoys in forum METALWORK GENERALReplies: 2Last Post: 13th Aug 2010, 04:20 PM
