Results 1 to 9 of 9
Thread: Piper Tapping Chuck
17th Apr 2011, 09:07 PM #1.
- 6,459
Piper Tapping Chuck
This is a superseded Piper chuck. Stuart asked whether I would dismantle it and post some photos.
Could not be more simple. The spindle has two drive dogs in the form of a square pressed in dowel. These dogs engage a pair of lugs inside the housing, providing drive when cutting a thread . When down feed is removed, the housing is raised up disengaging the drive lugs and the dogs, in turn, engage the gear on the spindle which, through the planetary gear assembly, reverses the spindle's rotation.
The red stuff is Timken grease.
BT
17th Apr 2011, 09:21 PM #2Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
great photos. how do you set the depth ofof the thread
18th Apr 2011, 11:56 AM #3Most Valued Member
Thanks BT,
I always struggle with planetary gears, are the rpms the same in reverse?
azzrock, I assume you can set the depth with the quill depthstop. Although all the machine tapping I have done was through hole and mostly done free hand.
18th Apr 2011, 01:19 PM #4.
- 6,459
I have not tried to use it to tap a blind hole to a fixed depth. From what I have read, you'd drill the hole over length and tap to the required depth. With the Piper, you could not use the quill stop because the chuck only reverses when the body of the chuck is moved upwards, disengaging the drive lugs. The reverse gear ratio is 2:1.
I had made a short video to show how it functions but for some reason I'm unable to upload it.
BT
18th Apr 2011, 01:46 PM #5Most Valued Member
But once the quill hits it's stop the tap would continue feeding until the clutch disengaged, then you let go of the quill feed and the reverse clutch engages. Although I'm not sure I would try this with a dog clutch in a blind hole as it would be disengaging and reengaging at maximum torque(even if it is only a 65% thread). The disengaging wouldn't to the clutch any good, the reengaging wouldn't do the tap any good.
2nd Mar 2016, 06:18 PM #6Pink 10EE owner
- 6,218
Here is Bob's chuck in action on the borer
https://www.youtube.com/watch?v=ucMHk-wJdbQ
2nd Mar 2016, 08:05 PM #7.
- 6,459
2nd Mar 2016, 10:24 PM #8Banned
- Aug 2015
- QLD
- 735
2nd Mar 2016, 10:53 PM #9
Here you go: Piper Tapping Chuck
Cheers, Joe
Help with tapping
By snowyskiesau in forum METALWORK GENERALReplies: 20Last Post: 21st Sep 2009, 03:41 PM -
Rhumba box tapping
By Scally in forum METALWORK GENERALReplies: 7Last Post: 8th May 2008, 12:35 AM
