Results 1 to 6 of 6
Thread: Chasers
16th Apr 2011, 05:54 PM #1logic
- Jan 2011
- sydney
- 90
Chasers
Have just been given 30 sets of used metric & unf Chasers with a machine I have just bought. Do any of you guys know if it is possible to use them without a diehead?
16th Apr 2011, 07:28 PM #2Most Valued Member
- 4,887
Are these Chaser or sets of 4 numbered dies that would normally fit into a die head.
16th Apr 2011, 07:58 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
I saw a dealer suggest you could weld handles to them, and use them as hand held chasers.
Jordan
17th Apr 2011, 05:34 PM #4logic
- Jan 2011
- sydney
- 90
Actually Jordon not a bad idea - not the welding thing - rather swapping them for some taps at a dealer's place. I am tapping stainless at the moment and going through taps by the bucket load. I am right at the tolerance for drilling diametres so more taps is the only solution.
17th Apr 2011, 07:09 PM #5Pink 10EE owner
- 6,216
Or you can use them as threading tools by putting them in the tool post...
I have used pipe chasers to thread pipe on the lathe... That way you get the tapered thread right...
18th Apr 2011, 04:59 PM #6Golden Member
- Cairns, Q
- 666
John Stevenson showed an example of this on one of the forums several years ago. When I needed to make a duplicate of my 10 TPI lathe headstock spindle thread I borrowed the idea, and the finished correctly shaped Whitworth profile thread turned out very nicely indeed. The partly cut thread is shown below. This chaser had been discarded because it had a chip out of one side, which was ground away to avoid any thread damage.
